My spectrum analyzer (SA) and my signal generator each has an input for external 10MHz reference signal, and also I have 10MHz from GPSDO.
As my SA does not have the internal tracking generator, I will use the external sig-gen.
All I want is to do is a simple sweep measurement on DUT across the defined frequency range.
How to connect the 10MHz signal source, topology wise, to these two equipments SA and sig-gen ?
FYI, the SA has only single port which can be configured either IN or OUT for the 10MHz signal, while the sig-gen has two separated ports, IN and OUT.
TIA
