Electronics => Beginners => Topic started by: Agony on May 12, 2013, 07:51:27 pm
Title: 105 SMD resistor tolerance
Post by: Agony on May 12, 2013, 07:51:27 pm
so i  "salvaged" a led  ring/strip  and looked at the resistors.
There are some 105-s, that look like  0.06W range, really tiny.
measured i get 720-730k ohms.
105 is rated at 1M ohm.
is that huge tolerance normal? thats around 27% less.
Title: Re: 105 SMD resistor tolerance
Post by: David_AVD on May 12, 2013, 09:29:18 pm
Maybe you fried them during removal?
Post by: Agony on May 12, 2013, 11:25:15 pm
didnt remove them, in circuit testing. .. too small to even bother removing.
https://www.circuitlab.com/circuit/fhp5xv/led-ring/ (https://www.circuitlab.com/circuit/fhp5xv/led-ring/)
Post by: Psi on May 12, 2013, 11:33:58 pm
They probably are 1M but other components in the circuit are skewing the measurement.
Or maybe your DMM is a cheapish brand and has a flat battery (cheap meters read wrong when getting flat)
Most likely the former.
Post by: Skimask on May 12, 2013, 11:34:45 pm
No, but if you look at your schematic, you've got resistances in parallel, and if you're trying to measure those 105 resistors in circuit, assuming all of those resistors are actually 1M and they are right on the mark for tolerance, you should read about 750K.  Factor in a bit of tolerance, and 720K-730K isn't that far out.
Post by: Agony on May 13, 2013, 12:34:53 am
the R3,R4,R5,R6 - they all were marked as "105" - 105 should be 1M.
But when i did some measuring - had a unregulated DC supply (17.6V under load) -  the current was very close - 7mA.
Thats what simulation gets me with 720k ohm resistors. With 1m ones the simulation suggested a 11mA - way mroe  then it actually measured.
Post by: David_AVD on May 13, 2013, 02:09:08 am
Measure the resistors out of circuit and tell us what they read.   ::)
Post by: Skimask on May 13, 2013, 02:42:22 am
You're not listening and/or reading...
You can't measure the value of those resistors "in-circuit".  There's too much other stuff going on.
And an unregulated 17.6v.  Who knows what kind of wave garbage is coming out of that thing...
Post by: metalphreak on May 13, 2013, 02:38:02 pm
You should look up how a voltmeter works. Also understanding that taking a measurement at two points is between two "nodes", so anything connected between those two nodes is measured. It might give you some clarity as to why you're getting the result you are.
The multimeter is putting out a small test voltage, the current from this is travelling through all the resistors in the circuit. What you are measuring is the combination of all the resistors at once in that configuration. You pretty much have to remove most components from a circuit if you want to test their values.
