Author Topic: 10A Buck Converter - RC Sevo's  (Read 761 times)
Offline DocaraTopic starter
« on: August 13, 2018, 07:49:27 am »
I'm just looking into the feasibility of driving  a couple of RC Servos from an automotive source and would like some advice.
First off the Servos will be either 7 or 8.4V and have a stall current in the range of 6-8A. And the Power cables would need to run approx. 2-3m.
Now I have only ever needed linear power supplies up to 2A so I've used our old friends the 78xx series. It is tempting to buy one of the multitude 10A+ Buck converters from our favourite auction site, but I don't know the implications are of using Buck converters with reference noise etc to surrounding equipment and to the electronics on-board the servos themselves - not to mention the long-term reliability
The alternative is to trawl through datasheets and use manufactureres application circuits to knock up a circuit without knowing good PCB layout practices or experience in this area.
Your thought would be most welcome
Thanks
Matt
Offline AustinR
Re: 10A Buck Converter - RC Sevo's
« Reply #1 on: August 14, 2018, 01:21:57 pm »
Reliability is component-specific, so I cannot comment on the longevity of using specific buck converters long-term.
However, I can comment a bit on controlling output ripple. Without knowing the specific application or requirements, I don't think you'd have to worry about servo issues too much, but using a capacitor on the output side of the buck converter should reduce how much ripple your servo is seeing.
I found a decent video on youtube covering this here: https://youtu.be/G-Llhy2ViUY
Hope it helps!
