Author Topic: Oscope reading open circuit  (Read 780 times)
Offline ArcticPhoenix0Topic starter
  • If it looks like I know what I'm doing, just wait.
« on: March 03, 2020, 12:48:27 am »
Newbie here with a simple circuit build. Trying to get an idea of how to use my scope so bear with me if this is clear and obvious.
4AA's
220o resistor
violet/blue LED
220uF cap (cap removed).
Just poking around with my oscope and can't figure out what I'm measuring here off the positive LED leg. The circuit is open; negative battery terminal is off the board and the cap is pulled. Still showing a reading on the scope and I can't explain why. Shouldn't it be showing a flat line?
Offline rstofer
Re: Oscope reading open circuit
« Reply #1 on: March 03, 2020, 01:03:07 am »
From the photo, it's not possible to determine V/div and time/div.  With all that antenna wire laying around, it is certainly possible to get a trace even though the voltage is likely to be quite low.  Try shorting out the probe or even removing the probe from the scope.  Then what happens?
« Reply #2 on: March 03, 2020, 01:07:42 am »
I'm thinking I'm picking up my house power. It's right at 60Mhz. 200mv and 20ms/Div.
This is what I get when everything's on and the probe is grounded to the negative battery terminal.
Online xrunner
  • hp>Agilent>Keysight>???
« Reply #3 on: March 03, 2020, 01:12:16 am »
I grabbed your image and expanded it on my pc. Your display is indicating F=60.0 Hz. That's picking up line voltage noise.  :-BROKE
Offline StillTrying
  • Country: Broken Britain
« Reply #4 on: March 03, 2020, 01:13:21 am »
It's just the normal few volts of 60Hz noise that an open circuit input, = the scope's input picks up.
Don't you find that everything slides off with the desk like that.
60 MHz
The following users thanked this post: ArcticPhoenix0
Offline james_s
« Reply #5 on: March 03, 2020, 01:30:53 am »
Scope inputs are very sensitive, a wire, your finger, anything that acts like an antenna will pipe a signal into it. Without any sort of tuner (filter) the power line frequency will normally dominate what you see.
« Reply #6 on: March 03, 2020, 01:38:52 am »
Quote from: StillTrying
60 [s
M[/s]Hz
Idk man, I'm still trying to figure it out. I can replace stuff that's clearly burnt out or suck up solder that's bridging IC pins but that's about it atm.
Offline rstofer
« Reply #7 on: March 03, 2020, 03:02:01 am »
This stuff takes time.  At least you have a first rate scope!
Put your finger on the tip of the scope probe and watch the trace go crazy at line frequency.
