Saying that ferrite bead is not an inductor is wrong. It is an inductor, and it's doing inductor things, opposing changes in current by storing energy.
It's rated for its impedance at a certain frequency. It could be rated for inductance like any inductor, but the type of rating reflects the supposed application of filtering high-frequency noise, instead of general-purpose use.
It also should be rated for saturation current (instead of max thermal current), but seldom is!
While a ferrite bead is supposed to have almost-zero DC resistance, you often expect the ferrite bead to be a lossy inductor, i.e., include AC loss component, so that while it slows down current changes by storing energy, it internally converts most of this energy to heat: this resistive impedance should be a large part of that 100 ohm rating. Equivalent circuit would be an ideal inductor with a parallel resistor: analogous to car suspension, the ideal inductor being the spring, and the parallel resistor being the shock absorber; and ferrite bead being a spring made of rubber which integrates both the spring thing, and the lossy element.
This expectation of AC loss isn't always right, it's well possible a certain ferrite bead isn't lossy enough but actually capable of releasing most of the stored energy, which, when combined with low-ESR capacitors such as ceramic, may cause amplification of noise, or resonant ringing, at certain frequencies. You need more data to be sure.
Also, if the current exceeds the (often unspecified) saturation current, then the inductance drops and it's just a piece of wire.
If you pick a ferrite bead with the highest impedance (ohms) rating, expecting to get most filtration out of it, it's likely to saturate at very low currents, and do nothing, especially if it's a small package.
So designing with ferrite beads required caution, and testing/deriving unspecified parameters.
