Author Topic: 120vac LEDs Six in parallel - One Flickers  (Read 439 times)
Offline NY2KWTopic starter
« on: January 31, 2020, 04:25:07 am »
2 years ago I bought some very attractive, pricey, recessed stairwell LED lights.  They are each wired 120vac in parallel and controlled by a regular wall switch.  One of the lights now flickers rapidly when turned on and I have to flip the wall switch numerous times until it finally stays lit.   I have monitored line voltage and it is pretty constant between 119-122vac.  I cannot get a replacement fixture... is the LED assembly something potentially repairable?
jerry
Offline Jwillis
Re: 120vac LEDs Six in parallel - One Flickers
« Reply #1 on: January 31, 2020, 06:17:31 am »
Could be the driver circuit is getting ready to pack it in on that one or it could very well be a poor connection at that one.I would check the connections are solid and go from there.
Can you get a couple photos inside the light fixture and  if you can any circuit board.
« Last Edit: January 31, 2020, 06:19:57 am by Jwillis »
