Author Topic: 12v Battery Charger Circuit using LM317 (12v Power Supply)  (Read 6410 times)
Offline queennikki1972Topic starter
  • We all start out as newbie's..be kind
« on: April 30, 2019, 03:45:02 pm »
Thinking about building this project.
https://circuitdigest.com/microcontroller-projects/12v-battery-charger-circuit-diagram-using-lm317 but I need someone to tell me if the circuit is incorrect and also decipher the BOM..
Specifically the recommended wattage for all resistors and (Diode- Nn007  (3)) Do they mean 1n4007 for example? They also mention a 0.05R - Shunt Resistor/wire but I dont see on the schematic.
I wont be using the Arduino nano or lcd
Siglent SDS 1202X-E - Heathkit IO-4105 - Dr. Meter 0-30v 5a power supply - 862d+ combo unit - Weller WLC100 - Kunkin KL283 DC load. Not much gear yet.
Re: 12v Battery Charger Circuit using LM317 (12v Power Supply)
« Reply #1 on: April 30, 2019, 03:54:31 pm »
Nevermind on the diodes, i see that it should probably be 1.5 amp diodes
Offline woodchips
« Reply #2 on: April 30, 2019, 03:57:16 pm »
What a bizarre circuit!
Look in any application note for the 117 for a LA battery charger that is far more subtle. It uses a low value, 0.5 ohm or so. series resistor between the out terminal and the voltage divider going to the adjust pin. This automatically adjusts the charge current as the voltage rises, work out how!
« Reply #3 on: April 30, 2019, 04:11:42 pm »
found it! Very simple circuit instead of this one.
http://www.ti.com/lit/ds/symlink/lm117.pdf page 24
Online Zero999
  • 0999
« Reply #4 on: April 30, 2019, 04:23:07 pm »
Connecting an LM317 current limiter in series with a voltage regulator circuit, like that is a bad idea, because it requires a lot of voltage headroom to work. The LM317 voltage regulator circuit, needs an input voltage of about 3V more than the input. The current regulator circuit needs an additional 1.25V, as that voltage is dropped across the sense resistor: 4.25V. An LM317 voltage and current regulator in series, require an input voltage of around 7.25V more than the output voltage. Then the diode on the output will drop even more voltage.
A 12V transformer is much to low for this circuit. It needs an 18V transformer to stand any chance of working properly.
Yes, that's a better idea. Figure 34, on page 26, is also a good idea, if sensing the current on the negative terminal of the battery, is acceptable.
« Reply #5 on: April 30, 2019, 11:15:27 pm »
http://www.ti.com/lit/ds/symlink/lm317.pdf page 13 battery charging circuit "RS" means current sensing resistor? Im sorry for asking such dumb questions
« Last Edit: April 30, 2019, 11:20:11 pm by queennikki1972 »
Offline MarkF
« Reply #6 on: April 30, 2019, 11:36:41 pm »
Here is a circuit I found online some time ago.  There was a description but I didn't save the URL.
I have not built it but looks interesting to play around with.
« Reply #7 on: April 30, 2019, 11:46:45 pm »
MarkF that makes more sense to me. I assume that 1R0 is 1W means 1 WATT resistor.
Offline MarkF
Offline digsys
    • DIGSYS
« Reply #10 on: May 01, 2019, 06:14:20 am »
Quote from: queennikki1972
errr nope. 1R0 = 1.0 ohms (at 1W as stated)
Working with V=IR, as current increases, voltage across the resistor also increases following that formula. At near 0.6V ~= 600mA, it will start to conduct
and start bringing down the Vop. If you need more current, decrease the resistor value and vice-versa
Note: That type circuit is really only for "Trickle charging" at ~ 13.8V, it has no boost capability, as usually ~14.4V. That gets trickier :-)
Online Zero999
  • 0999
« Reply #11 on: May 01, 2019, 07:41:56 am »
I thought it meant series resistor, but the naming is arbitrary.
It's probably based around the one on the datasheet I referred to above.
http://www.ti.com/lit/ds/symlink/lm117.pdf page 26.
He's right. It should be a 1W resistor, to allow some leeway.
« Last Edit: May 02, 2019, 08:02:54 am by Zero999 »
« Reply #12 on: May 01, 2019, 02:45:40 pm »
Typo, 1 Ohm at 1 watt is actually what I meant to say. 1R0 1W = 1 Ohm at 1 watt
