Ok, inside there's a spliter board, the mini pc requires 12Volts @ 12Amp, the LCD requires 19Volts @ 1.3Amp, so I guess the spliter board contains a step up converter.
I can easly power the LCD with an XL4016 module from a 8S(24..33.6Volts) pack
Now I need a module capable of 12Volts @ 12Amp or more, I did had some from previous searches from what is available localy and:
Ridden DPS5015 is now in range of use, however, I can only get it on Aliexpress/Bangood and that will take some time
SZBK07 contains a terrible review on youtube, so skip it, or find a better review.
this 200W 15A review
https://youtu.be/glDXTyNsbWw is outputing 12V @ 12Amp but my russian isn't great
Did I miss any other modules ?
