Author Topic: BC547 Transistor  (Read 1298 times)
Offline Munyua44Topic starter
  • Country: ke
BC547 Transistor
« on: January 17, 2022, 04:56:24 am »
I have a PCB with BC547 transistor that has blown off. In my local store, they don't have the BC547 transistor yet i need this job complete immediately. Advice on the BC547 equivalent transistor that i should use instead.
Offline bob91343
Offline DavidAlfa
Re: BC547 Transistor
« Reply #2 on: January 17, 2022, 07:29:51 am »
BC548, 2N2222, 2N3904, BC337, BC945... probably can replace it.
The following users thanked this post: Munyua44
Online Zero999
  • 0999
« Reply #3 on: January 17, 2022, 10:34:11 am »
Just make sure the replacement has a high enough voltage/current rating
The BC546/547/548/549/550 are all pretty similar, but the BC547 has a voltage rating of 45V. If in doubt, get the BC550 or BC546, but as mentioned above, it's probably not critical and any small transistor will work.
https://www.sparkfun.com/datasheets/Components/BC546.pdf
Offline rob77
  • Country: sk
« Reply #4 on: January 17, 2022, 12:02:02 pm »
also check the gain of the replacement transistor (Hfe,H21e,beta) ... in some case too much gain or not enough gain can cause problems, but that heavily depends on the circuit itself.
Online Zero999
  • 0999
« Reply #5 on: January 17, 2022, 01:21:40 pm »
hFE is a good function test, but if the circuit is properly designed, then it shouldn't matter what it is. The data sheet specifies 110 to 800, but that only applies at a junction temperature of 25°C, VCE = 5 and IC = 2mA. It might be different under different conditions. It's just a rough guide.
TLDR: the transistor will typically have an hFE of around 200 on a transistor checker and if it's much below 100, then it's probably bad. Otherwise it's good and the circuit should work with it.
Offline Terry Bites
« Reply #6 on: January 17, 2022, 04:02:24 pm »
 Here are a few candidates:
https://uk.farnell.com/w/c/semiconductors-discretes/transistors/bipolar-transistors/single-bipolar-junction-transistors-bjt?transistor-polarity=npn&collector-emitter-voltage-v-br-ceo=40v|45v|50v|60v|65v&dc-collector-current=30ma|50ma|100ma|200ma|300ma|400ma|500ma|600ma|700ma|800ma|900ma|999ma|1a&power-dissipation-pd=400mw|450mw|500mw|540mw|550mw|575mw|590mw|600mw|625mw|640mw|650mw|700mw|710mw|750mw|770mw|800mw|810mw|870mw|900mw|940mw|1w&transistor-mounting=through-hole&no-of-pins=3pins&dc-current-gain-hfe=2hfe|5hfe|10hfe|12hfe|15hfe|20hfe|25hfe|30hfe|35hfe|40hfe|50hfe|60hfe|63hfe|75hfe|85hfe|100hfe|110hfe|120hfe|135hfe|140hfe|150hfe|160hfe|170hfe|200hfe&st=npn&min_max=f1000905
Anyone remember TUP and TUN?
Offline rob77
  • Country: sk
« Reply #7 on: January 17, 2022, 08:40:17 pm »
are you trying to tell me if i replace a transistor with Hfe 100 with one with Hfe 400 that the circuit will function as expected regardless of the nature of the circuit ? for example  the quiescent collector current in a class A amplifier will not change if i use a transistor with different Hfe ? .. common...
sure, if the transistor is used as a switch, then it's in driven into deep saturation and the gain of the transistor is not that important..
Offline magic
« Reply #8 on: January 17, 2022, 08:57:25 pm »
It surely is possible to make something that depends on β, like it is possible to bias a simple common emitter stage (is this what you meant?) independently of β, using base resistive divider and an emitter resistor.
Anything mass produced tends to avoid β dependence to eliminate selection and tweaking costs :-/O
Offline rob77
  • Country: sk
« Reply #9 on: January 17, 2022, 09:04:48 pm »
sure, but no-one seen the OP's schematic, therefore no-one knows for sure and that's why i mentioned that gain needs to be checked as well when choosing a replacement.
Offline MK14
« Reply #10 on: January 17, 2022, 09:06:44 pm »
Don't forget, the OPs been banned, I think it is because they are a spammer. E.g. This question (OP) has been spammed in a number of different places, and may not be a genuine question.
Offline rpiloverbd
  • Country: bd
« Reply #11 on: January 21, 2022, 01:37:47 pm »
