Welcome,
Guest
. Please
login
or
register
Did you miss your
activation email
1 Hour
1 Day
1 Week
1 Month
Forever
This topic
This board
Entire forum
Google
Bing
Home
Help
Search
About us
Links
Login
Register
Electronics
Beginners
diy sop16 breakout board
« previous
next »
Print
Search
Pages: [
1
Go Down
Author
Topic: diy sop16 breakout board (Read 1132 times)
m3vuv
Super Contributor
Country:
on:
February 16, 2022, 08:12:24 am »
Hi all i need a sop16 breakout board/adaptor,would anyone have pcb artwork in pdf format for laser printing,as plan to etch my own rather than wait weeks for delivery,Tia.
Logged
Zipdox
Regular Contributor
Country:
Re: diy sop16 breakout board
Reply #1 on:
February 16, 2022, 08:49:05 am »
That's like 5 minutes in EasyEDA, do it yourself.
Logged
m3vuv
Super Contributor
Country:
Reply #2 on:
February 16, 2022, 09:49:22 am »
belive me if i could i would,for some reason any cad software sends my pc nuts.,thats why i am asking ok.
Logged
jpanhalt
Super Contributor
Country:
Reply #3 on:
February 16, 2022, 10:09:19 am »
What do you want the TH attachment to be? DIP? How wide?
Logged
m3vuv
jpanhalt
Super Contributor
Country:
Reply #4 on:
February 16, 2022, 10:34:35 am »
Here it is: (attachment)
Let me know if you want the package outlines removed. I suspect so.
Logged
m3vuv
m3vuv
Super Contributor
Country:
Reply #5 on:
February 16, 2022, 10:42:37 am »
its for one of these ok,tia.
https://www.aliexpress.com/item/1005001592303429.html?spm=a2g0o.productlist.0.0.6175a877lCryDK&algo_pvid=48fc8e83-c23a-42e4-93e2-cd57a8de5b8c&algo_exp_id=48fc8e83-c23a-42e4-93e2-cd57a8de5b8c-0&pdp_ext_f=%7B%22sku_id%22%3A%2212000018033300106%22%7D&pdp_pi=-1%3B18.18%3B-1%3B-1%40salePrice%3BGBP%3Bsearch-mainSearch
Logged
m3vuv
Super Contributor
Country:
Reply #6 on:
February 16, 2022, 10:45:47 am »
its to print using toner transfer so needs outlines removing please,many thanks.
Logged
jpanhalt
Super Contributor
Country:
Reply #7 on:
February 16, 2022, 10:47:19 am »
Yes, that central footprint in the pdf I attached. With SOIC and SOP there may be some variation and you didn't specify scale. The attached pdf is on a 0.1" grid. At 1:1, the it will appear much smaller.
Logged
m3vuv
jpanhalt
Super Contributor
Country:
Reply #8 on:
February 16, 2022, 10:48:42 am »
What scale? Can you reduce a pdf?
Logged
m3vuv
jpanhalt
Super Contributor
Country:
Reply #9 on:
February 16, 2022, 10:52:16 am »
Here is is, everything except pads and traces (top) removed.
Logged
m3vuv
jpanhalt
Super Contributor
Country:
Reply #10 on:
February 16, 2022, 11:02:57 am »
Here it is printed 1:1
Be sure to confirm actual size that you get.
Logged
m3vuv
JustMeHere
Frequent Contributor
Country:
Reply #11 on:
February 16, 2022, 06:33:57 pm »
Go look around oshpark. People put boards on there to share. JLBPCB might do it too. For something like this, ordering it from EBay is a choice too.
Logged
m3vuv
tooki
Super Contributor
Country:
Reply #12 on:
February 16, 2022, 06:49:31 pm »
And bear in mind that SO/SOP and SOIC aren’t the same thing, and that different manufacturers use the terminology differently. The only thing they have in common is 1.27mm pitch, but there are (at least) 3 widths in common use.
Logged
m3vuv
Print
Search
Pages: [
1
Go Up
« previous
next »
Electronics
Beginners
Thanking...
EEVblog Main Site
EEVblog on Youtube
EEVblog on Twitter
EEVblog on Facebook
EEVblog on Odysee
