Hello everyone,
I need a DPDT device (like a relay) that should meet the following restrictions:
- the switching mechanism should accept 12V or more on the input
- the switching mechanism should not sink more than 1mA ( which mean roughly 100mW)
- the output pins should accept voltages from 0 to 20V (being able to drop to 0 is a must)
- the output pins should not have an resistance greater than 100 mOhms
- should be small enough to fit in a 8x7 mm rectangle
The following relay meet all the conditions except the size :
https://www.tme.eu/ro/details/ftr-b4ca012z/relee-electromagnetice-miniatura/fujitsu-takamisawa/.If you believe that this can be achieved using transistors or other ICs please let me know how would you do it.
Just as a reference, this relay should switch between a voltage input on board and a calibration circuit.
