Author Topic: 12v interupt  (Read 1517 times)
Offline VICTopic starter
12v interupt
« on: October 05, 2014, 05:32:35 am »
Hi Guys
 I am sure you will be able to help with the following.
I recently fitted a new flip front head unit to my car which is great except for the following problem.
When starting car (key turn between ACC and START) there is a split second power supply interupt to
stereo which makes the unit reset eg. fold in then fold out Really annoying. Is there anything i can put
in the acc lead to prevent this
Your help would be greatly appreciated.
Thanks in advance
VIC
Offline reportingsjr
Re: 12v interupt
« Reply #1 on: October 05, 2014, 06:19:24 am »
This is likely caused by voltage sag on the 12v system. Starting a car can make it drop down as low as 3v. You can try to add a filter inductor in series with the positive line into the radio and a big capacitor after that from positive to ground. Even that may not help though. Good luck!
Offline Whales
    • Halestrom
Re: 12v interupt
« Reply #2 on: October 05, 2014, 06:44:54 am »
That should solve your issue, but it hints are other problems with your car (assuming the radio is stock)
 - Your battery is not behaving correcty.  Eg too old or not big enough for your car
 - Your starter motor might not be healthy
 - Your engine might have a larger than normal mechanical resistance to startup
Hope it goes well :)
Offline Whales
    • Halestrom
Re: 12v interupt
« Reply #3 on: October 05, 2014, 06:46:17 am »
It's probably easier to source large diodes than large inductors.
