the problem only showed, up after a deep and full discharge when I left the equipment on.
with deep cycle batteries they do not say how many deep cycles you get. no guarantees you get the full nine lives.
- thanks
SLA's particularly don't like that, less so with a bit of age on them.
I've seen figures for 1000 charge cycles although you'd want to treat with with kid gloves in order to get that.
I use 12V 7A ones for night time pest spotlighting and even if you run them til the light dims repeatedly you're gunna shorten their life.
Once they start only holding a short charge, they're stuffed. You can piss around steady cycling/recycling them and desulfating them but you're only
