Input is 12V, output I need is 12.6V with 1Amps current limit.
Output connected: Lithium battery 8.1V to 12.6V range and a resistive load in parallel.
Since battery is also connected at the output, so current limit is required. Otherwise battery drains huge current, if limit is not there
