I agree with the previous poster; wrong tool, incorrect test premise.
However, if it works for your specific case and you're doing enough of it that using a regular multimeter resistance display is causing significant throughput issues, then I'd suggest replacing the multimeter with either a) one that has pass/fail threshold capability, with audio cues or b) a low-cost custom built something to achieve the same (perhaps a current source, with the voltage developed across the DUT being passed to a VCO, with audio output. Or a simple binary pass/fail tone).
