I appreciate all the reply's, still a little confusing. You you are saying to run a separate 12vdc wire to to K1, then the positive wire from the heater (only pulls 2 amps) to K0, and the ground wire from the heater to ground. If that's not correct would you mind a quick diagram? Thanks for the help, retired Sys Admin, never made it to board level systems.
