I ordered this 144 chinese LED ring light for my microscope, and the light wasn't any good.
In comparison to my 56 LED stock ring light it was same brightness, minus lower color temperature which made it even less bright. I modified it. Gave it 12V 2.7 amps, the thing melted a little bit. I mean, maximum it takes 1.25 amps and at that power it melted after about 20 minutes of work. Stock it is limited to 225 milliamps.
I modified it then a bit differently, gave it 18 volts and made a current regulator, limiting current to 650 milliamps. Now it is bright and does not melt. It is great at minimal to medium zoom, but when I use 0.5 barlow and do max zoom the picture is kinda dark.
It has 3 mm pointed LEDs. I was thinking of installing 5 mm pointed LEDs instead. There is also option for 5 mm straw hat none pointed LEDs. They all will fit nicely. Which would be a better option in your opinion? Pointed or none pointed?
Pointed light
None pointed light
