The way I test the output section of a power source, for example, is this:
I take a power supply that can provide sufficient voltage / power.
I then connect the output section directly via twisted connection cables to the power supply and measure then over the 0.1 Ohm resistor R17 how the signal looks.
Which signal? connect a function generator to pin-5 of U7B.
Set the DC shift on the function generator so that the desired test current is running.
Now also set the AC signal to the function generator, usually I start with 500Hz and 10% duty cycle block signal.
Even now I measure over R17 and the signal should not have any overshoot!
If the signal has overshoot, the compensation is not correct yet.
And now the difficult part. Now place a resistor in series with the + connection of the power supply.
Test with 1, 5, 10, 22, 100 Ohm, think about the current, at 100 Ohm you usually can not run 2 Ampere.
Make sure you stay in the linear area of the dummy load.
The higher the chosen resistance, the lower the bandwidth, especially with the proposed power mosfets.
This is due to the large feedback capacities of the power fets.
It is easier to get a larger bandwidth with fast audio transistors in the power section.
Designing a good dummy load is not easy and at least 75% of your time goes to getting the output section properly stable and bullit proof
Down hear some links of some older design of mine, there are a lof of measurements, use Google translate becaue i'am Dutch, sorry fore that
https://www.circuitsonline.net/forum/view/121338/4#highlight=load+dummyAnd one with Audio power transistors
https://www.circuitsonline.net/forum/view/106770/1#highlight=load+dummyMaybe my designs give you guys some inspiration...
Kind regards,
Blackdog
