Hi all,
I need your advice for the following situation:
In order to power a camera surveillance system over nigh I've built an 18650 pack in the 7S10P configuration.
from that a DPS3005 (30V max input, 5A max output) buck converter is used to get the voltage down to 12-13v or so.
the DPS3005 needs a minimum of about 13.76v to give 13v output.
for 3.5V min and 4V max per cell we have the following voltages:
- 7S : 24.5V discharged, 28V charged
- 6S : 21V discharged, 24V charged
- 5S : 17.5V discharged, 20V charged
- 4S : 14V discharged, 16V charged - minimum configuration for 13v output of buck.
the question is:
what is the configuration that gives the smallest buck converter loses but still have decent Wh from the pack ?
asking this because the 7S at 28V buck input gives about 5W of loses for 13V @35W of consumption.
Have not yet tested the other configurations, thus the question.
Thank you,
George
