Author Topic: Overwhelmed by number of FET drivers. looking for recommendations  (Read 1048 times)
Offline cbc02009Topic starter
Hello All,
As I've posted previously, I'm working on a solar panel controller for a class project. My portion is the buck converter that inputs the voltage from the panel and outputs the correct voltage for the battery.
The number of mosfets and mosfet drivers on digikey is frankly overwhelming, and I really don't know where to start other than picking one at random (is that what people do?)  I was hoping someone could throw me a couple of recommendations of parts that maybe they've used in the past, just so I have somewhere to start.
Or maybe there really isn't much difference between them? In that case, is there a brand you prefer?
The only real constraint so far is that it be able to switch  at ~100Khz. I think I need it to be high-side, as well (at least, that's how I've designed it.)
The mosfet is easier for me to find, since I can narrow the listings down on digikey quite a bit, but recommendations would also be appreciated. including safety margins, I'm looking for something that can handle ~4A and ~25V. I was thinking something like this: https://www.digikey.com/product-detail/en/stmicroelectronics/STD150N3LLH6/497-8889-1-ND/2071115 although it might be overkill.
Thanks!
Online T3sl4co1l
    • Seven Transistor Labs
Re: Overwhelmed by number of FET drivers. looking for recommendations
« Reply #1 on: May 11, 2018, 09:00:19 pm »
If you need bootstrap, I forget which ones are high current output, search around.  HIP2101, IR2110, not too bad.
TC442x series are pretty typical for higher current (low side) drive, up to 18V.  There's an improved IXYS (IXxxxx) version too.  For higher voltages and currents, there's the IXDD614CI and relatives.  The cost goes up as you go into higher currents, and IXYS in general. :P
Seven Transistor Labs, LLC
The following users thanked this post: cbc02009
« Reply #2 on: May 11, 2018, 09:28:53 pm »
Thank you so much! I will take a look at those data sheets!
« Reply #3 on: May 11, 2018, 10:09:31 pm »
Yeah, the IXYS looks like massive overkill for this project. The HIP2101 look like exactly what I'm looking for though. Thanks again!
