Author Topic: How can i modify my speedometer?  (Read 11097 times)
Offline crazy_driverTopic starter
« on: January 29, 2014, 01:52:27 pm »
I need some help to try to calibrate a speedometer so i can change the face and put one with 260km/h.
Bigger pictures here: http://mk1tdi.blogspot.pt/2013/09/golf-mk1-gti-instrument-cluster.html
I have one from a 1.9 diesel ibiza 200km/h (1994) and one from a ibiza GTI 240 km/h (1995) found on ebay.
Both are K=3853 IMP/KM and both circuits have the same reference, only one letter and two different numbers on the vdo chip.
The 93S06 should be the chip to change the settings right?
The circuit only has 3 conections, +12v, signal and ground. The 4th is not conected on the cluster and the +12v has condensers in the circuit that i used on the new circuit and it works fine.
Thanks ;)
« Last Edit: January 29, 2014, 01:55:27 pm by crazy_driver »
Offline N TYPE
Re: How can i modify my speedometer?
« Reply #1 on: January 29, 2014, 02:47:04 pm »
You're welcome
« Reply #2 on: January 29, 2014, 04:05:32 pm »
i have the same wheels, what i need to change is the scale not the imput. Thanks ;)
Offline Towger
  • Country: ie
« Reply #3 on: January 29, 2014, 05:06:06 pm »
The speedos in Europe are calibrated  about 10% too low, in order to take into account people changing the wheel size.  I believe this is done as the car manufacturers can be held responsible if the speed is displayed too high.
Edit 1: Crap spelling
Edit 2: Changed low to high!
« Last Edit: February 05, 2014, 02:12:37 pm by Towger »
Offline zapta
« Reply #4 on: January 29, 2014, 05:32:42 pm »
You're welcome
Found the schematic here
http://archive.siliconchip.com.au/static/images/articles/i1081/108157_3mg.jpg
What kind of signal is it?
(I am working on a similar concept for linbus signals).
Offline N TYPE
« Reply #5 on: January 30, 2014, 02:44:11 pm »
You're welcome
It's normally a square wave pulse.. with varying frequency.
Offline N TYPE
« Reply #6 on: January 30, 2014, 02:55:36 pm »
It may be easier/more convenient to just get the speed sensor from the GTI and swap it over.
« Reply #7 on: January 30, 2014, 03:00:26 pm »
i have both speedometers, the sensor is the same and the speedometers look the same on the inside so something sould be making a different scale so that one shows maximum 200 and the other one 240, but maintaining the same signal from the gearbox sensor so that the odometer doesn't read more than it travels.
Offline zapta
« Reply #8 on: January 30, 2014, 05:15:38 pm »
Does the same signal also drives the odometer?
Offline Excavatoree
« Reply #9 on: January 30, 2014, 05:23:37 pm »
Can you find the data sheets from the ICs in the cluster?   The VDO brand clusters used on some Ford and Chrysler vehicles in the US use a common IC that has a resistor divider that sets a "divide by" ratio.    My "police car" cluster had a trim pot, but the "civilian" cluster used two resistors.  Yours may have a similar feature.
If not, the idea presented above, using an aftermarket divider/multipler, is your best bet.
« Reply #10 on: January 31, 2014, 12:44:59 am »
the same signal from the gearbox hall sensor drives odometer and speedometer, so if i modify the signal the odometer will register too much travel.
i'm a noob so all i know about electronics is by playing a little with this stuff.
the motorolla sc7812op chip is on the front
http://3.bp.blogspot.com/-gVovNBbvgkg/UjYQqt_vXlI/AAAAAAAAAsQ/ESSTZx34HTE/s1600/front_h.JPG
the 93s06 on the back maybe could have the info i need?
http://1.bp.blogspot.com/-c1a0S2ebO_A/UjYQpxwvpII/AAAAAAAAAsI/7bN2MVBChR0/s1600/back_h.JPG
Offline macboy
« Reply #11 on: February 04, 2014, 05:32:54 pm »
The speedos in Europe are calibrated  about 10% too low, in order to take into account people changing the wheel size.  I believe this is done as the car manufacturers can be held responsible if the speed is displayed too low.
Edit: Crap spelling
Care to cite a reference for this claim?
Offline magic smell
  • Country: si
« Reply #12 on: February 04, 2014, 06:50:18 pm »
Yust swap the complete cluster and it will work yust fine. I had made the same with golf, i put in 1,1 gasoline the cluster from gti.
Offline dr_p
« Reply #13 on: February 05, 2014, 12:30:04 pm »
Edit: Crap spelling
http://en.wikipedia.org/wiki/Speedometer#Error
Offline Rerouter
« Reply #14 on: February 05, 2014, 12:39:05 pm »
Unless that eeprom stores the calibration factor i am not seeing any easy way for you to accomplish this with both the pointer and speedometer reading accuratly,
sometimes the air coil driver has a span adjustment, but i do not recognize this circuit, though i see no other purpose for that micro / eeprom on there other than that and possible an odometer reading mirror (to tell if it has been changed) read off the contents you may find the K in plain DEC,
as far as factory calibration goes to reply to the above poster, higer Utes regularly come new from the dealer 23% fast, (My company occasionally fits correction boxes)
