Hi Everybody,
The project is simple, I am trying to build a digital clock, this requires a 1Hz timing.
My idea for the 1 Hz timing is to use a 32.768KHz crystal and then count the crystal using a 15-bit counter(2^15 = 32768), this would give me 1 sec.
I built up the circuit (Pierce oscillator),
Capacitors = 18pF.
Rfeedback = 1M ohm.
The inverter is a 74HC04 by TI(Texas Instruments).
I tried measuring the wave form using my arduino's digital read and this is what i keep getting.
I need help, is this actually correct, I do not have an oscilloscope.
