Electronics => Beginners => Topic started by: zorkwan on October 13, 2013, 12:34:05 am
Title: 2.4ghz amplifier
Post by: zorkwan on October 13, 2013, 12:34:05 am
http://postimg.org/image/c0bj4wcjh/ (http://postimg.org/image/c0bj4wcjh/)
heres the img how i think..
is there any way to amplify 2.4ghz wifi signal..i have 3 bars of 5 ...and if you have any diagram how to build one .Thx
just need to know if i can or not
Title: Re: 2.4ghz amplifier
Post by: AlfBaz on October 13, 2013, 01:25:38 am
Just tape a coat hanger to your wifi dongle
Post by: madshaman on October 13, 2013, 01:57:43 am
Do you think you will need to ensure that you don't amplify the transmitting signal since it will also be on your antenna?  Do you plan to amplify both directions of communication?
Post by: hedgewallace on October 13, 2013, 02:18:44 am
You can buy WiFi boosters. Just put it in an area that has pretty good reception (4 or 5 bars) and it should boost your range a bit.
Check out this link: http://www.pcmag.com/article2/0,2817,2372811,00.asp (http://www.pcmag.com/article2/0,2817,2372811,00.asp)
One thing you might also want to look at is a network power line adapter. it's pretty much an adapter that can transmit network signals from an Ethernet cable through your power cables in your house. You would plug one adapter in near your modem, and the other adapter in near your computer, or WiFi router.
Post by: alxnik on October 13, 2013, 03:18:18 pm
wifi is duplex. An amplifier will boost tx signal but rx will stay the same so the link will not be any better. To have a better link you need a better antenna.
Check your other post, you will find info there.
Post by: zorkwan on October 13, 2013, 05:35:04 pm
no just the receiver
Post by: zorkwan on October 13, 2013, 05:41:26 pm
so you mean that i cant amplify my receiver,only  my transmitter ,,cant understand why
theres signal coming from my transmitter to the receiver(antenna) and from my receiver ad a amplifier to get better signal and from there to my usb wifi adapter - and pc
antenna- to amp -to wifi adapter- to pc
Post by: alxnik on October 13, 2013, 08:49:06 pm
I don't think there are any amplifiers that amplify the receiving signal, only transmit. Most probably you will get nothing anyway. What matters is the SNR (signal to noise ratio). If you amplify the receiving signal, you are amplifying the noise too. The only way to reliably get a better link is to get a higher gain antenna which must be directional. A yagi wifi antenna costs about 25 euros on ebay, and I doubt you will find a receiving signal amp (if it exists) with that kind of money.
Post by: tszaboo on October 14, 2013, 03:52:38 am
Just put an LM358 in non inverting configuration with a gain of 1,4  :palm:
Post by: Kryoclasm on October 14, 2013, 08:43:41 am
This works  a treat, but it is directional and ugly.
http://www.makeuseof.com/tag/how-to-make-a-wifi-antenna-out-of-a-pringles-can-nb/ (http://www.makeuseof.com/tag/how-to-make-a-wifi-antenna-out-of-a-pringles-can-nb/)
Post by: HamiltonHipster on October 14, 2013, 09:53:23 am
I was thinking a LM741 because of its superior noise characteristics.
Zorkwan, you might want to try the coat hanger or pringles. Is 3/5 bars so bad? does it drop your data rate below whats provided by your ISP?
Post by: ee.jmlp on October 14, 2013, 11:31:54 am
put a reflector in a places where the signal does not come to concentrate the received power in the antena. Not every distance will be ok, you must move it according of the power level received. Better if the reflector is concave or parabolic with its focus on the antenna.
Aluminium would be okay. Treat wifi singnal as light you cann't see.
Post by: madshaman on October 14, 2013, 12:49:47 pm
So you're absolutely sure the transmitted signal won't get in your amplifier, by reflection or other means?  How do you plan to ensure this?  (Maybe google "diplexer" and "duplexer")
Post by: tszaboo on October 14, 2013, 01:27:14 pm
Are you aware that for amplifying a 2.4Ghz signal you need something, which has bigger gain-bandwidth than 2.4Ghz? Which is usually high-end stuff by itself, and you need $$$ equipment to test it if it is working properly or not.
Post by: AlfBaz on October 14, 2013, 01:31:11 pm
Oh... Surely he was being sarcastic
Post by: tszaboo on October 14, 2013, 01:33:32 pm
OK, I thought someone actually took my LM358 bait...
Post by: zorkwan on October 14, 2013, 02:46:43 pm
i bought a new antenna and have full internet access no data drop  ;D
Post by: madshaman on October 14, 2013, 03:36:15 pm
There's plenty of surplus high bandwidth amps on eBay fairly cheap, even more in the selective 800-900Mhz, 1750-2200Mhz and around 2.5Ghz for cellular, cellular data and wifi.
Post by: geraldjhg on October 14, 2013, 06:30:54 pm
hi
buy an amplified usb cable ant take dongle outside
could work
