Author Topic: Gas Discharge Tubes GDT  (Read 724 times)
Offline Wallace GasiewiczTopic starter
« on: November 27, 2022, 02:01:31 pm »
Does a GDT degrade over time or is degradation only related to number or magnitude of over voltage events?
Offline Ian.M
Re: Gas Discharge Tubes GDT
« Reply #1 on: November 27, 2022, 03:03:07 pm »
It depends - some older GDTs used a radioactive doped gas fill (or radium doped electrodes which emit traces of radon gas) to minimise dark effect.  If the radioactive isotope used had a half-life of a few years, the breakover voltage of an antique N.O.S  GDT may have increased significantly with age.  However IIRC radioactive GDTs have been banned in most jurisdictions and most datasheets for recent and current parts will state the tube is made with non-radioactive materials.
« Last Edit: November 27, 2022, 03:05:09 pm by Ian.M »
Online T3sl4co1l
    • Seven Transistor Labs
« Reply #2 on: November 27, 2022, 04:15:24 pm »
I don't know if GDTs are manufactured to avoid it, but neon tubes notoriously degrade over time and use, due to oxidation and other contamination of the electrodes, or dilution of the gas (which, usually the bulb is sealed fine, but if helium is used, it diffuses very slowly even through solid material).  It's possible the same effect applies, but it can be alleviated (giving longer, if not unlimited, life) with proper manufacture.
Also, needless to say, GDTs don't discharge very often, whereas neons can continuously.  So it might be effectively irrelevant in practice -- if it lasts say millions of surges (or whatever the datasheet says), you're already well outlasting a MOV.
Which is kind of a good reason to avoid a radioactive type anyway, if you need super long life equipment (20yr+).  Just as well, eh?
Seven Transistor Labs, LLC
Offline Terry Bites
« Reply #3 on: November 27, 2022, 05:30:01 pm »
Read this:
Offline TimFox
« Reply #4 on: November 27, 2022, 05:42:36 pm »
With conventional neon indicator bulbs (NE-2, NE-51), my experience with degradation in continuous use was that metal from the electrodes sputtered to the interior surface of the glass, darkening the bulb.
A bit of radioactive material was also used in some gas-discharge voltage-regulator tubes to ensure starting the discharge.
An interesting list:  https://www.royalsignals.org.uk/articles/radioactive-valves.pdf
« Reply #5 on: November 28, 2022, 11:47:25 am »
Thank you all for your comments. I was just thinking about a 145 Volt GDT as a protective device on a input circuit on a HP 3456. I suppose that with the essentially non triggering  of the tube, it is not necessary to replace it. I also bought some NOS 145 Volt GDTs that are probably 20 yrs old. I suppose these are still good and will outlast me.
I believe these are more modern tubes without the radioactive gas and that for this particular purpose, unless there is a leak the GDT is good.
