Ok, thanks everyone.
I am constantly confused about ESR readings... Is that chart for that meter the same for all other ESR meters? or roughly?
I find myself thinking higher voltage caps have high ESR, but I think that is the way it should be?
I also find it confusing how it shows up like 0.00 everytime on my meter. I never see 0.0 readings.
the chart linked earlier says 0.9?for 16v 100µf, for another rating, it lists 0.25?...
+ 1 on the seems normal opinion.
Most 70's equipment I repair gets a full recap of all electrolytics. Too often, leaving the original caps in a piece of gear that has been idle for the last 20 years of its 40 year life only leads to the gear coming back for repair after a year of active use.
I would only test, compare and retain small electrolytics if there was an interest in maintaining some degree of "originality".
Also note there is a 40% difference in ESR. To me, that is a suspicious on its own.
Thank you, exactly what I thought. Just the discrepancy between the 2 made me wonder, considering they are the same..
This thing has a lot of caps besides the 2 in question.
The thing is an analog synthesizer if anyone wondered.
Although, sometimes I wonder if a total recap is the way.
Then people say that there is no way all the caps are bad, etc...
I suppose full recap is the right thing to do. Preventing any future repair over the caps (hopefully).
Thanks again everyone!
