As TK and tggzz have said -- a regular 555 is far slower than 100 MHz, hence you will not observe any difference. But for signals which are approaching the bandwidth limit fo your scope and probes, the amplitude drops caused by the scope and the probes, respectively, will add up.
While you are learning, keep an eye on the unit designations and make it a habit to capitalize them correctly. The "m" prefix stands for milli = 1/1000. The "M" prefix stands for Mega = 1 000 000. And the unit for frequency, Hertz = 1/s, is abbreviated as "Hz" with a capital H. While spelling Hz as "hz" is merely irritating, mixing up "m" and "M" is really messing up your numbers.
