If you split your post into multiple paragraphs, it would be easier to read.
I think you've overlooked the importance of a thermal fuse. Relays, including the solid state variety, have a nasty habit of failing on, which can cause a fire if it's over-temperature and can't turn off. When safety is concerned, you need to consider what can go wrong, more than what it should be doing, when it's working properly.
