Author Topic: uCurrent Gold - trace to shunt resistors has no soldermask  (Read 1318 times)
Offline mathews616Topic starter
« on: January 12, 2020, 09:55:49 pm »
I was going through the uCurrent project and noticed something that seemed unusual to me. In the image, the trace connecting R1 to the input jack is (a) of differing trace widths, and (b) has no solder mask for a small portion.
Does anyone know if there's a reason for a small portion of the trace to be different from the rest? I can't think of an electrical reason, except maybe controlling the trace impedance with a different trace width but that doesn't explain why there's no solder mask. Is the exposed trace meant to help during testing?
Offline floobydust
Re: uCurrent Gold - trace to shunt resistors has no soldermask
« Reply #1 on: January 12, 2020, 10:47:41 pm »
PCB Rev. 5 - it's a 25 mil trace with 125 mil traces connecting to it. Makes no sense to me, I think it's a pcb layout error.
Offline Dave
  • Country: si
  • I like to measure things.
« Reply #2 on: January 13, 2020, 09:06:14 am »
I think the idea behind it is to be a weak link in the circuit (a fuse). Although I doubt it would function as one, as the surrounding copper is likely going to suck the heat away way before it bursts.
<fellbuendel> it's arduino, you're not supposed to know anything about what you're doing
<fellbuendel> if you knew, you wouldn't be using it
« Reply #3 on: January 13, 2020, 07:40:21 pm »
Probably there to reduce heat coupling from the input leads to the sense resistor, and to act as a very poor fuse, if you plug it into a high current supply in parallel rather than in series.
Offline schmitt trigger
  • Country: mx
« Reply #4 on: January 13, 2020, 08:40:04 pm »
Very likely a fuse. Even if it is an unintended one.
The following users thanked this post: Yansi
Offline thm_w
  • Non-expert
« Reply #5 on: January 14, 2020, 12:19:36 am »
Discussed here: https://www.eevblog.com/forum/oshw/current-gold-hw-design-question/
Straight from the horses mouth.
The following users thanked this post: hsn93
