Author Topic: Solid state relay/switch that needs low supply current (uAmps)?  (Read 2194 times)
Offline raff5184Topic starter
Hi I'm looking for a solid state SPST Form B relay that can be activated with current in the order of microamps. Even a simple digital switch that can work with a supply as low as 1.5-2V and microamp would do the job.
All the relays I found need at least 1mA for activation.
Thank you
Online David Hess
  • DavidH
Re: Solid state relay/switch that needs low supply current (uAmps)?
« Reply #1 on: March 28, 2020, 10:23:16 pm »
If it does not need to be isolated, then any analog switch can meet that requirement.
There are bistable latching relays which do not require any power to maintain state.
If I wanted a minimum power all solid station solution with isolation, then I would pump charge through a pulse transformer to control one or more power MOSFETs.  A forward polarity pulse through the transformer charges a capacitor which holds the MOSFET gates on.  A reverse polarity pulse discharges the capacitor shutting the MOSFETs off.
Offline Zero999
  • 0999
« Reply #2 on: March 29, 2020, 10:13:24 am »
Thank you
Form B means normally closed. David's idea is a good one, but will need depletion mode MOSFETS and the transformer set up to give negative gate voltages, to turn them off.
Another option is to AC couple the signal via small capacitors, assuming the capacitance bridging the two circuits is acceptable and a slow off time isn't a problem. The resistors will need to be high value >1M for low current draw and a dual gate IC such as the 74HC2G14 will also help.
If safety/mains isolation is required, use Y1-rated capacitors for C1 and C2 and adhere to the minimum creepage distances on the PCB.
« Reply #3 on: March 31, 2020, 12:19:19 am »
thank you for your replies. Timing is not  an issue. But what do you mean with isolation?
Offline wizard69
« Reply #4 on: March 31, 2020, 12:57:07 am »
I'm not convinced that detecting current is the easy way to go here.   When this device is activated is there a signal you can tap into to indicate operation?
Thank you
Online David Hess
  • DavidH
« Reply #5 on: March 31, 2020, 03:16:08 am »
It is commonly done with enhancement mode MOSFETs but either could be used.  A similar circuit is used for transformer isolated gate drivers where amplitude does not vary with duty cycle.
Offline Jwillis
« Reply #6 on: March 31, 2020, 04:52:39 am »
Relays are used to isolate between a low current low voltage control over high voltage high current.  If that is your intention  then simply using a transistor to boost the very low uA current signal to trigger a latching relay would work.
« Reply #7 on: March 31, 2020, 02:09:45 pm »
I'm not sure if my question and problem were clear, so I'll try to clarify them, even though you have probably already answered. I need something very basic like Figure 2: https://www.allaboutcircuits.com/technical-articles/basics-of-ssr-solid-state-relay-the-switching-device/ my circuit is DC and I have no timing constraints.
I need a voltage controlled switch,  something like these:
https://www3.panasonic.biz/ac/e/search_num/index.jsp?c=detail&part_no=AQY412S
https://www.mouser.com/datasheet/2/240/lcc110-1546141.pdf
The problem with those is that, if I understood correctly, the minimum LED current to make the switch toggle is typically of at least 1mA. Therefore, for all the duration that I need the switch to stay "active" I need to power the input LED with 1mA but that is too much. So I'm looking for an option that absorbs less current
Offline Zero999
  • 0999
« Reply #8 on: March 31, 2020, 03:03:54 pm »
In this case they must be depletion mode because the original posted asked for a form B relay, which is normally closed, so the transistors will have to be normally on.
https://forum.digikey.com/t/understanding-form-a-form-b-form-c-contact-configuration/811
In your first post you said you wanted a form B relay, which is normally closed.
Can we see the bigger picture? What exactly are you trying to do? Please post a schematic of the circuit where this SSR is going to go.
« Reply #9 on: March 31, 2020, 03:11:19 pm »
Yes and I still need a N.C. type of relay/switch, but low current.
Sure, I'll post a schematic
« Reply #10 on: March 31, 2020, 03:27:25 pm »
« Last Edit: March 31, 2020, 03:33:23 pm by raff5184 »
Offline Zero999
  • 0999
« Reply #11 on: March 31, 2020, 04:40:54 pm »
It is the design of my other post here:
https://www.eevblog.com/forum/projects/power-consumption-of-circuit/msg2985292/#msg2985292
This is the schematic:  https://www.eevblog.com/forum/projects/power-consumption-of-circuit/?action=dlattach;attach=957974
I want a N.C. switch on the right to replace the CPC1114N
Why create a new thread? If you'd stuck to the other one, you could have saved both yourself and everyone else a lot of time. :palm:
What does the CPC1114N switch?
The logic of the comparator circuit can be reversed an a normal open relay can be used.
« Reply #12 on: March 31, 2020, 05:55:15 pm »
It closes the power on a PCB that has FPGA, microcontroller, ADCs...
The comparator as you can see has hysteresis. Its output is high (switch is OPEN) when Vin goes from 0 to 4.4V.  At 4.4V output goes LOW (switch goes to NC position). Then, output of comparator goes high again only when Vin goes below 2.2V. Notice that I changed the values of the resistors according to the suggestion in the other thread.
Yes, I tried to reverse the logic but probably did something wrong and it wasn't working
Offline Zero999
  • 0999
« Reply #13 on: April 01, 2020, 08:06:21 am »
Then power the comparator off the same power supply as the FPGA/MCU PCB and use it to switch a MOSFET.
« Reply #14 on: April 01, 2020, 10:52:01 am »
Ok I'll try with a MOSFET. Buy why do I need to power from the other source?
Offline Zero999
  • 0999
« Reply #15 on: April 01, 2020, 02:37:59 pm »
Why not?
Obviously if the comparator isn't powered from the super capacitor, then it won't discharge it.
Offline nigelwright7557
    • Electronic controls
« Reply #16 on: April 01, 2020, 11:22:18 pm »
You can get photo voltaic opto-couplers to supply enough power to switch mosfets.
Offline Zero999
  • 0999
« Reply #17 on: April 02, 2020, 10:44:47 am »
The trouble is they require milliamps for activate but the original poster wants something which will work with a few µA.
Online Ian.M
« Reply #18 on: April 02, 2020, 12:02:28 pm »
Hmmm, (ignoring the O.P's requirement clarification and considering the more general case he originally requested), if gate leakage current of the MOSFETs is low enough, a pair of back to back MOSFETs driven by a 4000 series CMOS flipflop powered by a small 12V alkaline battery (e.g A23) could be used to implement a latching SSR, good for close to the shelf life of the battery.  Use pulse transformers to drive S and R as optocouplers could cause excessive battery drain.  Although it would need significant input current to switch, that would only be for a few tens of us S or R pulse, so the average input current could be sub 1uA.
« Last Edit: April 02, 2020, 12:10:43 pm by Ian.M »
« Reply #19 on: April 04, 2020, 09:05:10 pm »
You mean a p-channel type? I'll need to order some. I only have n-ch type, meanwhile can I use it so it works in the same way?
Offline Zero999
  • 0999
« Reply #20 on: April 04, 2020, 09:41:36 pm »
If switching the 0V side is acceptable, then you could use a N-channel MOSFET.
Looking at the other thread, you've got the TLC3702 running from the LM285LPE, givign it only 2.5V. Not only does this waste power, but the TLC3702 is only specified to work down to 3V, so it might not even work. Run it from an unregulated voltage between 3V and 16V. The unused section can also be used as a logic inverter, if you want the opposite output logic, without having to change any of the resistors and inputs round.
« Reply #21 on: April 04, 2020, 10:37:38 pm »
The ideal would be that the MOSFET allows current only when gate voltage (output of comparator) is LOW. That's why I thought of a p-ch MOSFET.
I actually removed the LM285LPE driving the TLC so I don't waste power. I'll use an unregulated voltage
If I use the other section of the TLC3702 (that I now disabled connecting the input terminals to V+ and GND using resistors) doesn't it require twice the power? But regardless, would reversing Vref and Vin on the input pins of the second comparator work, I mean Vref to IN- and Vin to IN+ ?
« Last Edit: April 04, 2020, 10:43:09 pm by raff5184 »
Offline Zero999
  • 0999
« Reply #22 on: April 05, 2020, 11:44:01 am »
It makes no difference whether the other comparator is doing anything useful or not, since it's on the same IC and will therefore be drawing current irrespective. It's much easier just to use it to invert the signal and drive an N-channel MOSFET, than modifying the circuit to invert the logic. Some of the resistor values could also be increased to reduce the current further and a decoupling capacitor is recommended, as close to the comparator IC, as possible.
« Reply #23 on: April 05, 2020, 12:17:34 pm »
Fantastic! Very clear. Thank you so much, can't wait to test it :)
