Author Topic: 24V Transformer  (Read 647 times)
Offline metrologistTopic starter
24V Transformer
« on: January 14, 2019, 09:31:37 pm »
I found this leftover from grampa's stock. It has the E laminating plates and the winding in a plastic housing. There is no "end" to the E laminating plates. (El).
Were transformers ever made this way or was this one taken apart? Also, the laminates are not stuck together but are a little loose. Think I can use this?
Offline Yolk
  • :yolk:
Re: 24V Transformer
« Reply #1 on: January 15, 2019, 03:00:07 am »
If you mean that the laminations are all missing the I piece,that's a problem,but if it's only the last lamination as in the end of the transformer,probably doesn't matter too much because it doesn't need it.
If the laminations are loose,the core will wobble and that's a problem (It will also wobble when it's firm and set,but it will do it ever so slightly. Serious wobbling will lead to losses and damage to the transformer.)
Maybe a picture?
