Hello Everyone!
I want to make a simple circuit but now i have one question\problem. I want to control one LedStrip (40Leds \
~450mA current consumption) with one sensor PIR
like this one and control one 5mm LED at same time, when LEDstrip is ON the LED is OFF and vice versa.
This PIR have
3.3V (Hight) at the Output Pin when motion is detected
So, i made this circuit and works very well with my
ATX power supply (for simulate the 3.3V input):
But now when i test with the PIR Output the circuit don't work, probably i have to amplify some how the 3.3V from the sensor, can you please help me with this? Probably i must put another transistor between the PIR and this circuit (BD139).. but what the best way to do it?
Thank you.
