I have a Chinese branded Teclast T-51 DAP (digital audio player) which is the same as the Nationite s:flo2 model.
Looks like an early iPhone. This model is from 2010.
Inside are TWO batteries apparently in series (balanced) config. I have not taken the protective wrapping off the batts to see the exact wiring config. or the protection PCB. I'm going to assume each battery has its own PCB. I can measure the voltage to about 7.2v when fully charged (which isn't long). The unit charges via std. micro USB (5.0 v).
Yes, they lasted 12 years in fairly regular (daily) use for about 10 years. But now, time to replace the battery!
Dimensions: 25x90x5mm for EACH battery.
I can find NO info on the OEM batt., so no clue as to mAH capacity, etc.
Ali and ebay have several options.
Please suggest something given the parameters I have provided.
Photo below of interior of DAP with batt:
Photo below of exterior:
