Author Topic: 30 Amp Automated Variable On Off Pulse  (Read 527 times)
Offline itsme1414Topic starter
« on: May 19, 2019, 10:21:32 pm »
I was able to determine the 30 amp DC power amp I would need to use for my solenoid project.
Now I need to find out if there is anything made you can purchase that has adjustable on off times
Example would be a high power adjustable strobe controller.
Need to come out of the amp into something that can be an infinite loop timer that could have variable on and off times for each pulse but could handle 30 amps.
Does anyone make this or can anyone make this?
Thank you
Offline pwlps
Re: 30 Amp Automated Variable On Off Pulse
« Reply #1 on: May 21, 2019, 03:53:36 pm »
A LED lighting strobe controller ? Not sure they can handle such currents, but could be used to drive a 30 amp SSR.
