Just curious... 58a sounds like a lot for locked rotor amps on a small motor. Are brushes and commutator in good condition? I've seen LRA numbers like this on 10,000 btu ac units. What passive solutions have you tried so far? (caps, chokes, etc..) What did you measure?
You're absolutely right, this is a fairly substantial "locked rotor" amps. I was surprised to measure such a high value for such a small motor after all. The previous owner sent the tool back to the manufacturer, Dewalt, indicating that he was simply fed up with the tripping breakers situation. Almost each time he was starting the tool, the circuit breaker tripped. Dewalt changed the brushes and the power cord. Once the owner got it back, the same situation was still reoccurring so the problem seems to be at the design level, hypothesis to which the manufacturer won't agree, obviously.
Just by the way the owner was describing the situation, I had a strong feeling that we were dealing with an inrush current situation. In fact, I experienced a similar situation with my central vacuum cleaner unit few months ago. Every so often, as soon as the switch was toggled on the handle, the circuit breaker was tripping. To solve the problem, I ran the appropriate wiring from the unit to the electrical panel, then added a 20A breaker so that the unit would be alone on its circuit, as suggested by the manufacturer. The manufacturer manual was indicating that a 20A breaker would be more suitable. Anyhow, since that fix/mod, the breaker never tripped again, so having my wife happy makes me happy too !
I tried the tool on the same circuit as my central vacuum cleaner and the breaker doesn't trip. Still measuring a 58A inrush current with my clamp. What is spoiling the fun here is the fact that the new owner need that tool at different sites, mostly residential. Unfortunately, 20A circuits with appropriate breakers doesn't seem to be a common practice. Most circuits are equipped with 15A and are tripping with that "stupid" tool. For what it may worth, information wise, the tool is a Dewalt grinder, DW831, type 3.
By the way, I had a similar issue with my 2KVA variac. Even if the dial is at its lowest, no load connected, the breaker is tripping too frequently. Using a time delay relay with my variac, wasn't too complicated. I simply relocated the ICL power switch at a more convenient location on my workbench, so the switch on the variac is always on, I just turn on the Inrush Current Limiter whenever needed.
Being able to use the same ICL device for different tools is a must. Also, modifying the tools isn't something I want to do as this action will void the warranty instantly. So yes, having the switch on the load side makes the overall thing a bit more tricky but I'm sure there is a way.
Beside measuring the inrush current with my clamp, I didn't try anything else. I wouldn't mind attempting some "passive solutions", but I don't know how to determine what would be the appropriate cap or choke to start with. It might not be of any use, but just in case, I measured the tool's DC resistance at the plug and I have a reading averaging around 1.5 Ohm, which seems rather small. Just for the sake of it, I also measured the inductance which gives me a reading in the 8mH range. With an inductance of that value, we come up with an inductive reactance of approximately 3 Ohms @ 60Hz.
Beside these measurements, I don't quite see what else could be measured and useful.
Hoping this is making the things a bit more clear.
