Hi
If everything is hooked to the same power supply, *and* the power supply has a TON of common mode noise .... you will never ever notice it. As soon as you hook any properly grounded gizmo into the mix ... lots of hum.
For example: Some supplies will have 60V AC on the chassis. The same 60V is also on the negative when it is hooked to the chassis. It also shows up (in phase) on the output in this case. Hook a voltmeter between positive and negative .... no AC to be seen. Hook a voltmeter to a good ground, check either one .... 60V AC ...
Bob
