Author Topic: Am receiver frequency readout  (Read 5348 times)
Offline RascalTopic starter
« on: June 24, 2013, 12:47:52 pm »
I have a 1960's un-cased  'home brew'  valve radio receiver that covers 60mhz to 186mhz. This is tuned by a mechanical mult-turn pot.
I have decided to build the receiver into a case. Unfortunately it doesn't have a frequency readout so I thought it would be an idea include some kind of indicator to do this.  I require something that gives me an idea of the frequency it is tuned to - to the nearest 5mhz would be sufficient.
Preferably I would like to use an analogue meter to achieve this.  I have a connection from the local oscillator (frequency + IF of 21.4mhz) - would it be possible to use this?
Any ideas or suggestions would be appreciated.
Paul
Offline Mr Smiley
Re: Am receiver frequency readout
« Reply #1 on: June 24, 2013, 01:39:51 pm »
How about a mechanical dial and a scale drawn behind it, tune a station, mark the dial The old way  ;)
Simple   :-+
Remember, the Americans spent millions developing a pen that writes upside down in space. the Russians used a pencil  :-DD
There is enough on this planet to sustain mans needs. There will never be enough on this planet to sustain mans greed.
Offline digsys
    • DIGSYS
« Reply #2 on: June 24, 2013, 01:50:53 pm »
Quote from: Mr Smiley
It's a multi-turn pot. You could use a 10Turn 3Digit Potentiometer dial ie Vishay Spectrol 15A31B10
Another idea is to have a slave 2nd gang pot that drives a meter. If you have to do it via the circuit, we'd need to see the circuit.
Offline vk6zgo
« Reply #3 on: June 24, 2013, 02:14:16 pm »
If it uses a pot,it must adjust the bias on a varicap.
Make a high impedance voltmeter & connect it to read the bias voltage.
You can try this with your DMM first to see if is workable.
Offline Radio Tech
  • KC4UMO Buddy
    • Hobby Forum
« Reply #4 on: June 24, 2013, 02:19:35 pm »
Simple   :-+
That is what I would do. it is old school, I keep it that way.
rofl!
We americans always seem to go around our elbows to get to our A**
 :scared:
« Reply #5 on: June 24, 2013, 02:54:35 pm »
Thank you for your replies.
I used the word 'pot' out of context - apologies. The receiver is tuned mechanically via a multiturn dial through a slow motion drive- the actual mechanism drives an arm along a coil.
Is it possible to use a pre-scaler circuit to divide the local oscillator down to a manageable frequency - then use a LM2907/17 or maybe a ne555 to covert to a voltage?
If possible - any ideas on the pre-scaler circuit?
Thanks again
Paul
Offline c4757p
  • adieu
« Reply #6 on: June 24, 2013, 02:56:00 pm »
Pencils make conductive dust that floats in microgravity, you'd be a moron to use that.
Offline vk6zgo
« Reply #7 on: June 24, 2013, 02:58:41 pm »
Simple   :-+
rofl!
 :scared:
Maybe the Americans were worried about pencil sharpener shavings floating around inside the spacecraft! ;D
There is no upside down in space,anyway!
Offline Radio Tech
  • KC4UMO Buddy
    • Hobby Forum
« Reply #8 on: June 24, 2013, 03:39:20 pm »
Simple   :-+
rofl!
 :scared:
Hmmm, you might just have a "point" there
Offline Mr Smiley
« Reply #9 on: June 24, 2013, 05:45:42 pm »
 :-DD
We're veering away from the op question  :--  Sorry about that  :-//
ps, they were pressurized ink cartridges, they half filled them with ink, popped in a ball bearing to create a seal between the ink and the top empty chamber and pressurized the empty section above the ball bearing before sealing the end, so the pressure pushed against the ball bearing and that provided a constant supply of ink, you can still buy them today commercially.
Was it worth millions  :palm:
Any way, back to the OP
Offline AlfBaz
« Reply #10 on: June 24, 2013, 05:49:16 pm »
Wasn't there a whole Seinfeld episode about it?:)
Offline kfitch42
« Reply #11 on: June 24, 2013, 06:16:02 pm »
The space pen is really an amazing story of the power of capitalism, not the epic fail that the one-liner would suggest.
http://www.snopes.com/business/genius/spacepen.asp
Offline Mr Smiley
« Reply #12 on: June 24, 2013, 06:31:35 pm »
I stand corrected   :clap:
NOW BACK TO THE OP  :-+
Offline edavid
« Reply #13 on: June 24, 2013, 07:12:38 pm »
The most common way to do this is to use a PIC-based frequency counter which subtracts the IF frequency, for example:
http://www.morsex.com/aade/counter.htm
If you look around, you can find DIY projects using the same concept.  You could adapt one to output PWM to an analog meter instead of using an LCD display.  You would have to add a prescaler also (Or is that frequency range a typo?  It doesn't seem very useful.)
Unless you're really opposed to microcontrollers, it's the easiest and best way to do the job.
« Last Edit: June 24, 2013, 07:14:40 pm by edavid »
Offline JackOfVA
« Reply #14 on: June 24, 2013, 09:22:19 pm »
Sounds like a Mallory Inductatuner, or a knock-off of Mallory's design.
If the main tuning knob only has one revolution or less then a mechanical dial is a good solution.
If the main tuning knob makes more than one revolution, then the mechanical solution is more complicated. But, perhaps one of the mechanical turns counting dials sold to be used with a multi-turn potentiometer would work. Purchased new they can be a bit pricey but can be found used at a more reasonable price.
For a electromechanical solution, I suppose a multi-turn potentiometer ganged with the tuning shaft and read out with an analog meter would preserve the period nature of the receiver.
« Reply #15 on: June 26, 2013, 12:58:48 pm »
Looks very much like a Mallory Inductuner
Paul
« Last Edit: June 26, 2013, 01:05:05 pm by Rascal »
