Author Topic: -3dB and an LPF  (Read 3394 times)
Offline eev_carlTopic starter
-3dB and an LPF
« on: November 28, 2018, 12:48:51 pm »
I have a simple passive LPF and was trying out the loss at fc.  I'm using the equation 20log(Vout/Vin) but wasn't getting the -3dB as I expected and was wondering if I had applied this incorrectly or was missing something like the effect of the phase shift.
My Vin peak-to-peak is 2V and Vout is 1.5V.  I get 20log(1.5/2) = -2.5dB.  The source of the formula is here: https://www.electronics-tutorials.ws/filter/filter_2.html .
Thanks,
Carl
Offline ogden
  • Country: lv
Re: -3dB and an LPF
« Reply #1 on: November 28, 2018, 01:16:56 pm »
LTspice can do calculation for you. Easy way: make sure simulation have at least 100 sine periods (.tran 10s) and run FFT which gives signal magnitudes in dB.
The following users thanked this post: eev_carl
Offline aneevuser
Re: -3dB and an LPF
« Reply #2 on: November 28, 2018, 01:27:55 pm »
Are you sure that you're measuring the 3dB point? The two signals should have a 45 degree phase shift at that frequency, and I'm not sure that your image shows that (though it could be my eyesight)
Re: -3dB and an LPF
« Reply #3 on: November 28, 2018, 01:54:52 pm »
I was measuring the ratio (1.5V/2.0V) at 159Hz which is the cutoff frequency.  I expected this to =3dB but was getting -2.5dB.
Online tggzzz
Re: -3dB and an LPF
« Reply #4 on: November 28, 2018, 01:55:35 pm »
You don't have a simple passive LPF, you have a simulation of a simple passive LPF.
Use the simulator's different types of analysis; in this case AC (i.e. frequency domain) simulation is enlightening.
Re: -3dB and an LPF
« Reply #5 on: November 28, 2018, 01:59:34 pm »
I also breadboarded the circuit and got a similar ratio (520mv / 700mv) for Vin/Vout.
Does this FFT analysis look correct?  I see a 0dB value at 159Hz but am not sure how this relates to the -3dB of a cutoff frequency.
Offline mvs
Re: -3dB and an LPF
« Reply #6 on: November 28, 2018, 02:13:49 pm »
Your measurement is not correct. You have measured first positive peak, that is 0.1V higher then all others.
Online tggzzz
Re: -3dB and an LPF
« Reply #7 on: November 28, 2018, 02:39:58 pm »
If you are using a solderless breadboard, then expect to spend more time debugging the solderless breadboard than your circuit. For alternatives, see http://bristol.hackspace.org.uk/wiki/doku.php?id=pcb#avoiding_solderless_breadboards
Those spikes lead me to believe your graph is a measurement rather than an analysis. Since we have no idea what you measuring, nor how, there's no point in us speculating about what the graph shows.
Re: -3dB and an LPF
« Reply #8 on: November 28, 2018, 02:42:20 pm »
Thanks.  I measured a few peaks down and found the ratio was more like 1.4/2 and that's -3.09dB.
Re: -3dB and an LPF
« Reply #9 on: November 28, 2018, 03:03:58 pm »
I'm measuring gain in decibels at the cutoff frequency.  Another poster pointed out that I was looking at the first peak and that subsequent peaks were lower, bringing me to that -3dB value I was asking about.
On the breadboard side, I'm forming the ratio with different scope settings (peak-to-peak, RMS, average).  I've also tried cursors but don't see the peaks getting lower the way I did with LT Spice.  Since it's such a simple circuit, I just clipped everything together and ditched the breadboard, but I'm still getting a ratio of 1.48/2.02 (Vpp).  Is there a better scope setting to measure Vpp?
Online tggzzz
Re: -3dB and an LPF
« Reply #10 on: November 28, 2018, 03:06:48 pm »
Your next task is to understand why that phenomenon occurred in simulation, and whether it would also be seen in a real circuit.
Online tggzzz
Re: -3dB and an LPF
« Reply #11 on: November 28, 2018, 03:14:02 pm »
If you are using a solderless breadboard, then expect to spend more time debugging the solderless breadboard than your circuit. For alternatives, see https://entertaininghacks.wordpress.com/2020/07/22/prototyping-circuits-easy-cheap-fast-reliable-techniques/
You are measuring far more than "gain in decibels at the cutoff frequency" - the graph goes from 0.1Hz to 20kHz with a measurement at all those frequencies.
Now I could hazard a guess at your experimental setup (signal source, UUT, measurement tools and techniques), but that's a waste of my time.
« Last Edit: May 14, 2021, 03:41:43 pm by tggzzz »
Offline mvs
Re: -3dB and an LPF
« Reply #12 on: November 28, 2018, 03:23:55 pm »
You may improve your measurement by selecting high resolution mode and/or selecting another V/div range. But in general scope is not a precision instrument.
Re: -3dB and an LPF
« Reply #13 on: November 28, 2018, 03:30:01 pm »
Thanks all.  My components were off.  My R was actually 9.88k and C was 94.5nF.  This gave me a fc of 170Hz, not 159Hz so my function generator wasn't set correctly.  The ratio, measured as V peak-to-peak was 1.42/2.02 and this brought me to -3.06dB.
Online tggzzz
Re: -3dB and an LPF
« Reply #14 on: November 28, 2018, 03:34:43 pm »
.. or rather it is a precision instrument as defined in the handbook - which is rather less precise than beginners imagine :)
A scope's prime function is to observe a signal's shape, and it does that well - within limitations.
Offline Berni
  • Country: si
Re: -3dB and an LPF
« Reply #15 on: November 28, 2018, 03:51:54 pm »
Just use AC simulation instead:
Online tggzzz
Re: -3dB and an LPF
« Reply #16 on: November 28, 2018, 04:24:24 pm »
As mentioned above :)
Plus he could give the resistor a 1% tolerance and the capacitor a 10% tolerance, and run a monte carlo analysis to see a range of possible cutoff frequencies:
The following users thanked this post: ogden, xzswq21
