Author Topic: PIC 12f509 The target has invalid calibration data (0x00)  (Read 8284 times)
Offline DuleTopic starter
« on: November 04, 2017, 07:54:08 pm »
Hello,
I am following Gooligum tutorials and I am getting an error mesage "The target nas invalid calibration data (0x00) when programming PIC 12F509 for lesson 4.
I have checked the internet and it appears that my program is somehow erasing OSCCAL value but I am not sure how is that possible whan I have the following in my code.
RCCAL  CODE  0x3FF
       res 1
RESET  CODE   0x000      ; processor reset vector
       movwf  OSCCAL
Also, I could not find any workaraound for this problem.
Thanks
Offline Mjolinor
Re: PIC 12f509 The target has invalid calibration data (0x00)
« Reply #1 on: November 04, 2017, 08:02:21 pm »
Not of direct help here but what I do whenever I get a tube of 8 pin PICs with a osccal value I read the whole tube and using a indelible marker I mark the byte by starting at pin one to pin 8 putting a dot on the pin if it is set in the byte. That way it doesn't matter how daft or careless I am I always have the value marked on the outside of the chip.
Offline FrankBuss
    • Frank Buss
« Reply #2 on: November 04, 2017, 11:23:18 pm »
If you have a PICKit 2, you can restore it with the standalone program. They don't list the software anymore on the product page for the PICKit 2 programmer, but you can download it here. Then you can use one of the tools menu to recalibrate it:
I didn't found any option for the PICKit 3 or in MPLAB-X to recalibrate it. I couldn't even find a standalone programmer software for the PICKit 3 on the official page, but some forum post refers to this program. Unfortunately looks like it is not possible to do it with this program:
Looks like @eevblog needs to do another PICKit 3 vs. PICKit 2 rant video :)
Offline jpanhalt
« Reply #3 on: November 05, 2017, 03:41:20 am »
I suspect this is not the first time you have tried to program the chip and inadvertently erased the calibration value on a previous erase.
That chip will run fine without the calibration in OSCCAL.  Just skip the "movwf    OSCCAL" step.  I have used the 12F509 many times without the calibration for programs that did not require accurate timing.
There are ways to re-do the calibration (attached) or Google for other code.  Note that method is for the 12F675.   Basically, you create a known delay and adjust the OSCCAL value so the chip matches.
Remember to set  FSR,5 to address Bank 1 where the value stored when you decide to save it.  You need to clear that bit in code or use a banksel command to return to Bank 0 for the rest of your code.  You can operate entirely in Bank 1 as the SFR's can be reached from either Bank, but I would return to Bank 0, if for not other reason than practice in bank shifting.
John
Offline amyk
« Reply #4 on: November 05, 2017, 03:56:39 am »
Clever and practical. :-+
« Reply #5 on: November 05, 2017, 08:14:16 am »
Thanks, I have pickit 3 :(
« Reply #6 on: November 05, 2017, 08:19:52 am »
I have tried with brand new, never used PIC. So far I think I ruined 3 of them :(
Is it possible that brand new PIC odes not have stored calibration value?
I have just started with PIC programming so I don't really know what I am doing. Is there any way to read memory of a pic using pickit3 and MPLab?
« Reply #7 on: November 05, 2017, 08:22:15 am »
Thanks, that sounds like a good idea. how do you read them?
Sorry for my ignorance I have just started with PIC so basically have very little knowledge.
I have pickit 3 and mplab
Offline Mjolinor
« Reply #8 on: November 05, 2017, 08:31:00 am »
They are not ruined, you can re-calibrate them by making a simple square wave using the internal OSCCAL value and working out what the frequency should be then adjust the value until you see the correct frequency on a scope or a frequency meter.
It really is very simple but time consuming.
MPlab will read them fine but it should be the first thing you do, before you write to it.
This is why I do it on all of them when I open a new tube. It's easy to say don't overwrite it in the datasheet but when you are concentrating on other things as you usually are then it is so easy to forget.
« Last Edit: November 05, 2017, 08:33:35 am by Mjolinor »
Offline jpanhalt
« Reply #9 on: November 05, 2017, 08:36:38 am »
I write absolute code, not relocatable.  However, the principles and most of the code are the same.
Have you tried removing the instruction I suggested?   If that didn't work, then remove this directive too:
Code: (asm) [Select]
RCCAL  CODE  0x3FF
       res 1
What is the rest of your code?  When you assemble, are you choosing relocatable or absolute?  Your chips are probably not ruined by the code.  They run fine without the OSCCAL calibration and when or if you need more accuracy, it is easy to fix.
It may be redundant to ask, but are the code protect fuses off?
John
« Reply #10 on: November 05, 2017, 08:51:47 pm »
I have, no success. I still get the following error message
Target voltage detected
Target has invalid calibration data (0x00).
Device Erased...
Programming...
The following memory area(s) will be programmed:
program memory: start address = 0x0, end address = 0x1e
configuration memory
program memory
Address: 0 Expected Value: 66 Received Value: 0
Failed to program device
Here is the whole program:
list      p=12F509            ; list directive to define processor
    #include <p12F509.inc>        ; processor specific variable definitions
    __CONFIG   _MCLRE_OFF & _CP_OFF & _WDT_OFF & _IntRC_OSC
; '__CONFIG' directive is used to embed configuration word within .asm file.
; The lables following the directive are located in the respective .inc file.
; See respective data sheet for additional information on configuration word.
;***** VARIABLE DEFINITIONS
        UDATA_SHR
sGPIO   res 1
        UDATA
db_cnt  res 1
dc1     res 1
;********** RC CALIBRATION
RCCAL  CODE  0x3FF
       res 1
       movwf  OSCCAL
; Internal RC calibration value is placed at location 0x3FF by Microchip
; as a movlw k, where the k is a literal value.
;****** MAIN PROGRAM
start
    clrf     GPIO
    clrf     sGPIO
    movlw    b'11111101'
    tris GPIO
main_loop
        banksel  db_cnt
db_dn   movlw    .13
        movwf    db_cnt
        clrf     dc1
dn_dly  incfsz   dc1,f
   goto     dn_dly
   btfsc    GPIO, 3
   goto     db_dn
   decfsz   db_cnt,f
   goto     dn_dly
       movf      sGPIO, w
       xorlw     b'00000010'
       movwf     sGPIO
       movwf     GPIO
db_up   movlw    .13
        movwf    db_cnt
        clrf     dc1
up_dly  incfsz   dc1,f
   goto     up_dly
   btfss    GPIO, 3
   goto     db_up
   decfsz   db_cnt,f
   goto     up_dly
   goto main_loop
   END
« Reply #11 on: November 05, 2017, 09:02:44 pm »
I have solved the problem, and I am an idiot.
I plugged PIC 12f509 in 8 pin socket on gooligum training board although it clearly says 10F. I should have plugged it into top portion of the 16 pin socket. Ahhhhh…
Now everything works.
Sorry for the time you wasted answering my questions and thanks a lot. I did learn few things out of this
Offline FrankBuss
    • Frank Buss
« Reply #12 on: November 05, 2017, 09:04:57 pm »
Glad you solved it. For the record, there are many possible problems with programming PICs. Some problems I had in the past:
- bad USB cable. Works with one cable, doesn't work with another, and doesn't work with an USB extender cable.
- programming voltage was too low. Worked with 5V, but not with 3.3V
- bad wiring: used it on a breadboard and the programming cables were to long. Reduced the speed with "Run->Set Project Configuration->Customize->PICkit 3->Opentio categories: Program Options->Program Speed". Easy to find, right?
And it doesn't help that there are no really clear error messages, even if the programmer is not connected at all to the microcontroller.
Offline orangepi
« Reply #13 on: March 10, 2018, 02:27:26 pm »
In my case, I want to know how exactly the following codes can protect the OSCCAL from being overwritten.
RCCAL  CODE  0x3FF
       res 1
gooligum insists that the above does the job. But It looks like it's allocating value '1' on the memory address 0x3FF where the OSCCAL is saved. That is, it's overwriting factory calibrated OSCCAL, isn't it?
I know that the assembler preserves the address 0x3FF by doing this so that even though the program grows bigger the last byte of 0x3FF is protected. But it's set a value 1 on 0x3FF.
« Last Edit: March 10, 2018, 02:31:03 pm by orangepi »
Offline orangepi
« Reply #14 on: March 10, 2018, 03:12:27 pm »
RCCAL  CODE  0x3FF
       res 1
I think the above memory is literally reserved, and if not used or referenced in the body of the code nothing is written to it. Is it right?
Offline MarkF
« Reply #15 on: March 10, 2018, 07:34:59 pm »
Just to clarify - A newer version of the PICkit2 Software (version 2.61) and Device Firmware (version 2.32) is available on the Microchip Downloads Archive
   http://www.microchip.com/development-tools/downloads-archive
(Near the bottom.)
