Author Topic: What is this connector called / where could I get more?  (Read 1226 times)
Offline michaeliv
« on: September 10, 2015, 07:47:52 am »
I have the following connector. Origin unknown. Where would I be able to get more / what should I search for ?
Do these type of connectors have a specific name ?
It's basically a 4mm cylinder that is part 3mm nut.
Thanks!
Offline Jesset1996.5
Re: What is this connector called / where could I get more?
« Reply #1 on: September 10, 2015, 08:54:26 am »
Could be some sort of rf connector! It looks like Something you would use for a radio antenna connection or even a wifi antenna extention cable. It is attached to coax cable after all so i would look for something similar on the Internet under rf connectors. It could also be a headphone jack of some sort  :-/O
Offline RobertHolcombe
« Reply #2 on: September 10, 2015, 09:12:33 am »
Looks like an SMB connector although the pictures are not very clear
