i have a 50 mhz dso with a 1gs/s sampling rate,i see an owon 200mhz scope with a 2ghz/s sample rate,how can it not need double the sample rate for 200mhz analog bw?.
It depends on oscilloscope specification.
There are two bandwidth for digital oscilloscope:
1) Digital bandwidth, which is a half of sample rate
2) Analog bandwidth which should be much smaller than digital bandwidth (at least 5-10 times smaller for budget oscilloscope and more than 20 times smaller for professional oscilloscope).
Larger gap between analog bandwidth and digital bandwidth allows to get better rejection of digital conversion aliases and images with analog filter on oscilloscope input frontend. Better rejection for aliases and images means that oscilloscope will show you less signal distortions. But it requires to use more expensive ADC converters and more fast and powerful FPGA for data processing.
Some oscilloscopes using more cheap ADC/FPGA with smaller digital bandwidth in order to provide you with more cheaper device. Yes, it can show you more distortions for signal than more expensive oscilloscope with more fast and powerful ADC/FPGA, but you get more budget solution. And for many cases such solution is pretty acceptable.
In short, if difference between analog bandwidth and sample rate/2 is higher it means that such oscilloscope will show you more true waveform with less distortions...
These distortions happening when measurement signal contains frequency components higher than digital bandwidth of oscilloscope. For 1 GS scope digital bandwidth is 500 MHz, so it will suffers from signals above 500 MHz on it's input, which usually have low enough level in home and diy applications, so you can use more cheaper oscilloscope with 1 GS for home needs.
PS: there is also exists specific type of oscilloscope - stroboscopic, it can have analog bandwidth more than digital one, but it has it's own limitation, because such oscilloscopes are intended to work with periodic signals, but this is different story.
