Regarding outputs: why would anyone think it's a good idea to connect an output directly to either power rail? Consider what would happen if the output tried to go high, when it's connected to 0V, or low, when connected to +V?
well, I always put pull-up and pull-down resistors so that no short circuit happens. in this case i believe 47k is the resistor value, so if it went from 0v to 3.3v, the resistor will act as a load and no short circuit will happen.
but as you suggested, i will float unused outputs and connect unused inputs to ground via 47k resistors.
What does active low/high mean?
in the case of 74 single flip flop ic, it is active low. meaning it will get activated when 0v is delivered to the input... while the "regular" status will require constant 3.3v (via pull-up resistor) to always be at that pin.
for my 4013b as seen, pulldown resistor is the default case making it 0v unless a HIGH pulse of signal is delivered to the pin which is exactly what I require. As I said, the external mod or system or circuit outputs active high pulses and I must deal with it.
You should be able to substitute the 4013 for the 74LVC1G74, but the connections will need to be changed.
well, i thought hooking the inputs to pull-up resistors to have constant 3.3v at input pins = not active. Then get 2 small transistor with their gates/base connected to my "On" and "Off" pulses so that these positive pulses can let the transistor pull the inputs to 0v which activates them.
However, this will add more parts. Yes, space can be lowered a bit but cost won't be affected really since 4013B is kinda the same price as 74.
Its datasheet says this:
~PRE -> Preset input - Pull low to set Q output high
~CLR -> Clear input - Pull low to set Q output low
meaning, using my suggested transistor pulldown circuit... I can hook my "On" signal to the PRE and "Off" signal to CLR (via transistor pull-down..etc) and this will achieve the same result. While everything else should be the same, like D and CLK as I layed them out in my original circuit.
do you think this is correct? I've done it before in the dual mosfet circuit in the image in first post, specifically the transistor which activates the rail.
I've quickly looked at the datasheet for Q5 and it doesn't appear to be a matched pair. It does say closely matched gain, but how close isn't specified, along with no mention of VBE matching. In reality the two transistors probably will be quite well matched any they will be well thermally coupled, but there's no guarantee. You need the BCM856 which is specified to be matched within 2mV of VBE and 0.9 for hFE.
No problem, I got this one:
https://www.lcsc.com/product-detail/C458150.htmlseems to also have the exact same footprint and pinout, so it is a drop-in replacement.
___
besides that, do you think the circuit will function as intended? i mean isolation, activation, etc..
