~One final question...So if lets say Q4 LED on each is Illuminated, it will only then trigger the 555?
Im having a problem that when any 1 led matches on either of the boards there is a triggering, of the circuit, altho I have hooked this up to Q3 only on each board
everything seems to be correct
