Hello.
I am experimenting with 4000 series logic chips. I tested some johnson counters and divide-by-n counters. Now i wanted to test my 4026. But it turned out all my 7 segment displays are common-anode type. If i was to interface my IC with these displays i would have to use 14 transistors. Can someone point out a common anode 7 seg. display driver IC, that would be similar to the 4026?
