Welcome,
Guest
. Please
login
or
register
Did you miss your
activation email
1 Hour
1 Day
1 Week
1 Month
Forever
This topic
This board
Entire forum
Google
Bing
Home
Help
Search
About us
Links
Login
Register
Electronics
Beginners
45mfd cap
« previous
next »
Print
Search
Pages: [
1
Go Down
Author
Topic: 45mfd cap (Read 611 times)
thedoc298
Contributor
Country:
45mfd cap
on:
June 23, 2019, 04:03:31 pm »
Is their any difference between a 45uf 250 volt run cap and a 45uf 250 volt start cap. I know that they are used for different purpose, but I think their should be no difference. Any ideas
Logged
Ian.M
Super Contributor
Re: 45mfd cap
Reply #1 on:
June 23, 2019, 04:07:25 pm »
A start cap has much higher losses. If you try to use one as a run cap, it *will* go BANG!
Logged
thedoc298
Contributor
Country:
Re: 45mfd cap
Reply #2 on:
June 23, 2019, 04:12:35 pm »
how would that be determend on a cap tester
Logged
ArthurDent
Super Contributor
Country:
Re: 45mfd cap
Reply #3 on:
June 23, 2019, 04:14:10 pm »
A motor start cap is a non-polarized capacitor (or 2 caps back-to-back) and designed for very short use time per start. I wouldn't use one for a DC power supply filter or visa versa. Very bad!
Logged
schmitt trigger
Super Contributor
Country:
Re: 45mfd cap
Reply #4 on:
June 23, 2019, 04:23:13 pm »
Start capacitors are almost always clearly labeled as such, because of the risk of running it continuously.
Its ESR is about 10 times that of a run capacitor of the same capacity and voltage.
Logged
thedoc298
Contributor
Country:
Re: 45mfd cap
Reply #5 on:
June 23, 2019, 04:29:48 pm »
Thanks, that is something that will show up. The original start did have very high esr. Thanks
Logged
Print
Search
Pages: [
1
Go Up
« previous
next »
Electronics
Beginners
45mfd cap
Thanking...
EEVblog Main Site
EEVblog on Youtube
EEVblog on Twitter
EEVblog on Facebook
EEVblog on Odysee
