Author Topic: 4mA-20mA current loop sensor  (Read 1064 times)
Offline roogadgetTopic starter
« on: September 19, 2018, 12:39:53 pm »
I want to use a 4mA-20mA industrial sensor with a microcontroller.
Do these sensors output 4mA-20mA by default? Or do I need a transmitter to take the input (probably pwm) and convert that to 4-20. ?
Offline NivagSwerdna
Re: 4mA-20mA current loop sensor
« Reply #1 on: September 19, 2018, 12:46:51 pm »
which sensor?
« Reply #2 on: September 19, 2018, 12:56:29 pm »
Here is an example
http://www.crmagnetics.com/Assets/ProductPDFs/CR5200%20Series.pdf
I guess this answers my question.. it outputs 4mA-20mA
Offline Zero999
  • 0999
« Reply #3 on: September 19, 2018, 02:57:24 pm »
A simple 250R resistor will give 1V to 5V from the 4mA to 20mA range.
« Reply #4 on: September 20, 2018, 09:54:44 am »
Here is an example
Indeed
The DS says... 4-20 mADC - 0 to 300 Ω (for some of the parts).... (0-5V for others)
So pick a resistor somewhere in that range https://www.omega.co.uk/techref/das/4-20ma.html has some info or if you want to get fancy... http://www.ti.com/product/rcv420
