Hello there!
So I wired 4 brand new gel batteries to be 24V for my RV / Solar.
The question is: Should I also wire "across"? (see diagram)
My general electronics sense tells me: doesn't matter, because 2x12V in series is really just 20 Lead acid cells in series.
But as the real world isn't optimal, would it be a better/worse idea to also connect the middle tap?
Thank you, everyone!
