I am against building rectifiers as a DIY project. WHY? SMPS have too much noise, although their pretty easy to build. Linear rectifiers are a combination of art and Zen. The idea of analog electronics is quiet. Once the noise is there, it's tough to get it out. They are not at all easy to build. The BOM has about 300 items, not including chassis and PCBs. There are infinitely more ways to fail than to succeed. But it's like anything else, the more time, effort and money you invest, the better the result.
60V is a bit much for a typical hobbyist. And 3A is a bit low. A 0-40V 0-5A would cover 95% of all projects. One of the difficult tasks is the readout. Definitely LED 7-segment down to mV and mA resolution. Tolerance is good at < 1 mV. And, Insurance is important, because home brew rectifiers ruin more expensive electronics than any other single thing in the history of creation!
And, for the time you put in, the parts you purchase, the boards you design, the endless hours of drudgery while friends are out having a blast, and not the remotest hope of any gain of any kind, it's always better to purchase a DC rectifier, or power supply (PSU). EBay has 200,000+ DC power supplies for sale presently. Lambda and Sorensen are the best major suppliers.
You can probably pick up a 0-40V 0-5A linear unit for $150 + $40 shipping. Have a look. And for a DIY project, choose something that has some potential for gain. One thing that's in big demand is highly accurate digital humidity gauges with temperature sensors, and basic functions like calculating dew point, of course an A/D converter to drive a digital readout.
There are humidity sensors with RTD temp sensors built in. That would be worth building, because such devices are in high demand, and sensors to make it feasible are a fairly recent development. The applications are endless. Industrial and scientific monitoring. Portable access to that information. You can run the entire device on 5VDC, so all it needs is a USB connector and smart phone reserve power brick.
So why don't I just do it if it's such a good idea. I have several inventions I hold the patent on, and I license use of them, or parts thereof. I have an electrical and chemical analytical lab. I'm designing a deep learning neural network AI rig. So, I don't want to do that too. But if you could design a linear rectifier that's 0-60V and 0-3A, you can definitely do the digital humidity &temp meter.
