Hello,
I am having a bit of an issue with understanding electrolytics. The standard polarized, not the less common bipolar ones.
What strikes me, when looking at a datasheet, the capacitance or ESR are often rated at a certain frequency. Like 120Hz or 100kHz. Latter maybe because of switching regulators.
But maybe we are not talking kHz AC, but pulsating DC (ripplevoltage)? Would make more sense after rectification as well.
However, asides the datasheet, I've seen quite a few designs, where electrolytics are used in the audio path to decouple DC. Probably because low frequencies require larger capactities. However (decoupled) audio is clearly AC or bipolar. How does that go together? Clearly you'll have the electrolytic reverse polarized for a moment. A short moment, but highly repetetive.
The final issue I do not really grasp is ripple current, also metioned in the datasheets. As opposed to ripple voltage, which occurs because the capacitor discharges, the current is determined by the load.
Sure, if the voltage drops, the current drops as well, assuming ohms law here. So I would understand a maximum current rating, but where comes the ripple into play here?
The ripple current seems to be different to the the current the capacitor is able to deliver, which is my main problem to understand.
Further, if there happens to be a regulator in between, then the load gets a constant voltage anyway and the drawn current is constant, just the regulator has to take care of the ripple voltage. So what is this about?
Quite obviously I am missing something very fundamental here and would appreciate some help to get back to the right path.
Thanks
