Author Topic: Easy way to get a 500mA load for testing?  (Read 3260 times)
Offline Jay112Topic starter
« on: May 16, 2016, 02:30:07 pm »
I'm sorry for this simple question, and I feel like the answer should be obvious to me, but...
I'm trying to test some triacs using this simple SCR tester circuit that I got from this page: http://www.sentex.ca/~mec1995/tutorial/triacs/triacs.html
The triacs I'm trying to test have a 500mA latching current, but I'm having trouble thinking up a way to get a 500mA load. I can get the triacs to switch on using the circuit above, but I can't test their latching ability because I need a greater load. Can you please give me some suggestions for how I can make/find a 500mA or greater load?
Thanks!
Offline Delta
Re: Easy way to get a 500mA load for testing?
« Reply #1 on: May 16, 2016, 02:35:07 pm »
A lamp, just like your picture shows!
6W at 12V is 500mA, so try a car sidelight or indicator bulb...
The following users thanked this post: Jay112
Offline klr5205
« Reply #2 on: May 16, 2016, 02:55:45 pm »
A simple current mirror can be made with 3 parts: a transistor, a resistor, and a diode (or diode-connected transistor)
The other obvious answer is of course just a 24 ohm resistor.
« Reply #3 on: May 16, 2016, 03:02:38 pm »
Thanks for responding! I couldn't seem to find any lamps that are higher than 500mA. The best I could find was a 1W 12V LED.
Thanks for the info! I'll have to study about current mirrors now, and I'm sure that'll be useful to me in the future. But I think the obvious answer of just using a resistor was what I was looking for. My mind wasn't working well because I'm tired of concentrating on circuits since yesterday.
Offline karoru
« Reply #4 on: May 16, 2016, 03:08:22 pm »
Discrete current mirror for half an amp, what can go wrong... ;)
Offline rstofer
« Reply #5 on: May 16, 2016, 03:22:48 pm »
Tail light/brake light bulb should be available at an auto supply store.
5 each 1/2 Watt 100 Ohm resistors in parallel - 600 mA
« Reply #6 on: May 16, 2016, 03:52:53 pm »
Thanks! I actually could have used the advice about putting them in parallel, because I forgot to match the power rating of the resistor! I got my dosage of magic smoke for the day. :)
Offline Chris Mr
  • Where there's a will there's a way
« Reply #7 on: May 19, 2016, 03:57:18 pm »
I have a reel of nichrome wire I use to make up dummy loads.
If you wrap it round a sheet of something you can use a croc clip to vary the resistance.
In your case though I would use a light bulb - diagnostics  ;)
