Author Topic: Using a salvaged transformer in a diy bench power supply?  (Read 4921 times)
Offline PotatoBoxTopic starter
« on: July 26, 2017, 04:49:56 pm »
So, I have a salvaged transformer that will output 22 volts with no load. I have no idea what it was I salvaged it from. It was some sort of TV channel selector with a remote. But anyways, I have no ratings for how much current it can output. Is there a way to figure this out? Would it be a good idea to use this transformer or should I just go out and buy a transformer so that I know the ratings of it?
Online Kleinstein
Re: Using a salvaged transformer in a diy bench power supply?
« Reply #1 on: July 26, 2017, 04:57:28 pm »
A channel selector does not sound like high power. One can get a first approximation from the weight and the ohmic resistance of the wires.
Another important point for a lab power supply is the safety: the transformer should be good for a class II device, so it is safe even without a PE connected to the output side. Most transformers good in that respect, but not all. Anyway I would be careful with transformers reused from some cheap units.
Offline schmitt trigger
  • Country: mx
« Reply #2 on: July 26, 2017, 05:37:16 pm »
Small transformers usually have a load regulation between 10 to 15%.
22 volts open circuit would mean between 19 and 20 volts at rated load.
If you have power resistors, you may use them increasing the load until you obtain that voltage.
Measure the load current.
« Reply #3 on: July 26, 2017, 11:39:30 pm »
So I would just do this through trial and error? Like slowly ramping up the resistance until I get 20 volts, then measure the current?
Offline rstofer
« Reply #4 on: July 26, 2017, 11:51:28 pm »
Technically, ramping down the resistance.  But, yes, you have the right idea.  The problem is, unless you have a variety of power resistors, this is going to cost more than buying the right transformer in the first place.
Online Kleinstein
« Reply #5 on: July 27, 2017, 01:30:48 pm »
With small transformers most of the voltage drop is usually due to the ohmic resistance. So one can just calculate the voltage drop from the resistance.  It is only with the very small (e.g. < 3 VA) transformers where it does not work that well, as the magnetizing current gets really important in these.  Increasing the load until the voltage drops by something like 10 % does not help very much: the larger the transformer, the lower is usually the drop in voltage at nominal load. To a good approximation one can get the same from measuring the ohmic resistance and doing the math. The main part is to estimate the power loss the transformer can dissipate without getting to hot. One unknown here is the quality of the insulation and thus the maximum rated temperature.
« Reply #6 on: July 27, 2017, 04:32:07 pm »
How do I measure the ohmic resistance?
Online Kleinstein
« Reply #7 on: July 27, 2017, 04:39:35 pm »
Most DMMs have a resistance range. So measuring resistance should not be so difficult - just make sure the transformer is not powered.
A few auto-ranging  DMMS don't like the high inductance of a transformer - so it might help to shorten the secondary side when measuring resistance on the primary.
Offline tablatronix
« Reply #8 on: July 27, 2017, 04:44:18 pm »
Does it have ANY markings on it?
Like xx-xx-xx or xx xx
« Reply #9 on: July 27, 2017, 04:47:23 pm »
Yes it has a variety of marks on it.
On the top of the transformer there is:
M-013
T 6C24H
and on the side of the transformer there is:
24E019HD
TAMRADIO
« Reply #10 on: July 30, 2017, 10:38:52 pm »
Alright I did a little more digging and apprently TAMRADIO is a brand of Tamura. I looked on Tamura's site for legacy datasheets but no luck.
Any ideas?
Offline Zero999
  • 0999
« Reply #11 on: July 31, 2017, 10:08:17 am »
Weigh the transformer and compare it to a data sheet for a similar type of transformer of approximately the same dimensions, core type (usually either toroidal or laminated for small units), frequency rating (50Hz units will be slightly heavier than 60?Hz units) and mass.
